DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Pump for Lynx 2 ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Bollbuster
from United Kingdom
PostPosted: Thu Jan 07, 2010 9:49 am Reply with quote
Hi everyone, you really helped me a year or so ago with a pressure problem and was really gratefull.
But, now the pump has gone on my Lynx 2 combi and according to Potterton via my local heating shop, the pump is obsolete and there is no replacement. I've had no heating or hot water for a week and am desparate. The pump is a Wilo Salmson Gold Star-P. Can anyone suggest anything? Date of boiler is 1994.
Many thanks in advance - I'm bloody cold!
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Thu Jan 07, 2010 9:59 am Reply with quote
Although the complete pump including special housing is obsolete.
You maybe lucky and be able to use the head off a standard Wilo pump they have changed slightly over the years so may not fit for the sake of 50 quid could be worth a try
Back to top
The following user says thank you to namsag for this useful post:
Bollbuster (7 Jan 2010)
 Alert Moderators
Bollbuster
from United Kingdom
PostPosted: Thu Jan 07, 2010 12:05 pm Reply with quote
Thanks for the tip, Ive emailed Wilo's technical dept to see if they can help with a replacement.
Anyone else got any ideas?
Bollbuster
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3531 times
PostPosted: Thu Jan 07, 2010 12:11 pm Reply with quote
I think that pump is a long shaft model which is no longer available.
However, it is possible to change the whole pump assembly with types which are available.
Tony
Back to top
The following user says thank you to Agile for this useful post:
 Alert Moderators
Bollbuster
from United Kingdom
PostPosted: Thu Jan 07, 2010 12:27 pm Reply with quote
You are all really helpful and many thanks to all.
I've had a reply from Wilo saying that maybe their Wilo Gold 60 may fit but I do not know the dimensions so I can check if fits face to face. Anyone know?
Thanks again,
Bollbuster
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3531 times
PostPosted: Thu Jan 07, 2010 1:20 pm Reply with quote
I think that any normal pump will fit but would need a photo to be sure.
Grunfoss pumps are more tolerant to the dirt in your system.
Tony
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Thu Jan 07, 2010 3:03 pm Reply with quote
Just had a look at the instruction book and it looks like it does not have a special housing and pump connection are both standard size.
Have a look at your pump and if both the unions at either side are the same size then any 15/60 pump should fit but have it on speed 3
Back to top
 Alert Moderators
powell30
from United Kingdom
Thanked: 129 times
PostPosted: Thu Jan 07, 2010 3:22 pm Reply with quote
Or beter yet change the blooming boiler......pile of dog do, cheaper in the long run i promise you
Back to top
 Alert Moderators
Bollbuster
from United Kingdom
PostPosted: Mon Jan 11, 2010 11:36 am Reply with quote
Thanks to everyone for their help.
I'm being told the Wilo Gold RS60 or Wilo Smart B will both do the job.
Does anyone have any preference ?
Thanks again Guys
Bollbuster
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Mon Jan 11, 2010 12:09 pm Reply with quote
Use the gold 60 wilo dont use a smart pump on a combi
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3531 times
PostPosted: Mon Jan 11, 2010 1:17 pm Reply with quote
As I said before, the Grunfoss is more tolerant to dirt.
Merely chaning the pump does not get rid of dirt.
If the old pump failed from dirt then the Wilo will fail quicker!
Tony
Back to top
 Alert Moderators
Bollbuster
from United Kingdom
PostPosted: Wed Jan 13, 2010 11:12 am Reply with quote
Well I got the Wilo Gold RS60 from my local Screwfix yesterday for 44, started draining down at 2pm and was running a nice hot bath at 4pm.
Everything seems to be ok and had it running on speed 2 till I realised this morning and put it on 3 as you have recommended - but why is that, out of interest?
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Wed Jan 13, 2010 11:52 am Reply with quote
It is a low water content boiler and the water within it needs to move fast so it does not cause localised boiling thus noise and scale.
Agile the old pump more likely failed with age than dirt , stop scare mongering next you will be saying he needs a magna clean
Back to top
 Alert Moderators
Bollbuster
from United Kingdom
PostPosted: Wed Jan 13, 2010 1:06 pm Reply with quote
Thanks namsag, I understand now. And yes the old pump is 14 years old.
Bolly
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3531 times
PostPosted: Thu Jan 14, 2010 2:36 am Reply with quote
Pumps dont fail from just age.
The most usual cause of most pump failures is seisure or worn bearings as a result of dirt in the system.
1990s Salmson pumps unfortunately had capacitors which lost their capacitance and thus caused a loss of torque.
Where possible I just replace the capacitor as thats cheaper for the client and easier for me.
A combi boiler is designed around a higher power pump running at full speed so that the maximum heat transfer is obtained on DHW mode.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton Lynx Airflow sensor 19 2320 Mon Feb 06, 2006 1:26 pm
Potterton Lynx air flow switch 5 1180 Fri Feb 10, 2006 9:29 pm
Pootterton Lynx 2 combi problem 15 540 Fri Feb 17, 2006 5:48 pm
potterton Lynx Electronic 4 580 Sun Mar 19, 2006 1:23 pm
Potterton Lynx 2 Boiler Problems - Help Required 4 1580 Thu Jan 26, 2006 1:18 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
