nigelwoodhead
Joined: 10 Feb 2005 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Feb 10, 2005 10:40 am Post Subject: wooden fence posts |
has any one used a mechanical hole borer? Can a 4 inch post be knocked into a 4 inch diameter hole satisfactorily? is concrete with a larger hole essential? |
chappers
Joined: 27 Aug 2004 Posts: 994 Location: United Kingdom Thanked: 0 times
Posted: Thu Feb 10, 2005 7:02 pm Post Subject: |
didn't your mother tell you you cant get a square peg in a round hole !
No seriously that will be fine but I would use some postmix as well. |
PowerTool
Joined: 21 Dec 2004 Posts: 192 Location: Durham, United Kingdom Thanked: 0 times
Posted: Thu Feb 10, 2005 9:14 pm Post Subject: |
Yes,it would be OK
I was taught how to put posts in using the traditional method (for hanging farm gates)
Cut turf off,and place to one side.
Dig a hole slightly larger than the size of the post.
Dig the hole deep enough to have half of the above-ground height below ground (i.e. 4' above ground needs 2' deep hole)
Place post in and check for vertical
ALL the soil that came out of the hole gets rammed back in to support the post.
Use turf removed earlier to finish off - job done!
Although it works,I could never really understand how all the soil goes back in the same hole,when you have filled most of it up with a whopping great lump of wood  __________________ HAMMER ACTION - when all else fails.. |
Thermo
Joined: 21 Oct 2004 Posts: 8454 Location: Sussex, United Kingdom Thanked: 31 times
Posted: Thu Feb 10, 2005 9:28 pm Post Subject: |
compaction __________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference |
kevplumb
Joined: 18 May 2004 Posts: 19149 Location: Tennessee, United States of America Thanked: 400 times
