DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Best way to remove an olive ?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
wittoner
from United Kingdom
PostPosted: Wed Jan 13, 2010 11:00 pm Reply with quote
Best way to remove an olive without damaging the copper pipe ?
Back to top
 Alert Moderators
glasgowgas
from United Kingdom
Thanked: 231 times
junior hacksaw
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 131 times
PostPosted: Wed Jan 13, 2010 11:02 pm Reply with quote
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 292 times
PostPosted: Wed Jan 13, 2010 11:09 pm Reply with quote
junior hacksaw cheapest
oliver remover the best
i use a junior
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 334 times
PostPosted: Wed Jan 13, 2010 11:20 pm Reply with quote
olive cutter for the pro's
a hacksaw blade for any size olive and any awkward place ,I always use proper hacksaw blade cant be doing with junior hacksaw icon_biggrin.gif icon_biggrin.gif
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
PostPosted: Wed Jan 13, 2010 11:56 pm Reply with quote
I've used side cutters before icon_lol.gif If your careful it does just a good job as a hacksaw...
Back to top
 Alert Moderators
IronNaz
from United Kingdom
Thanked: 11 times
Use a junior hacksaw.
However you might find it keeps slipping. The way to avoid it slipping is grip the area around the olive with pliers. Let the hacksaw glide next to the pliers, using the pliers as a guide. Once you have cut about halfway through the olive, using a thin 5 or 5.5. mm flat head screwdriver, push it into the grove you have just cut, and twist. It will snap the olive and easily remove it.
good luck.
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 131 times
PostPosted: Thu Jan 14, 2010 12:01 am Reply with quote
good luck.
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 2342 times
PostPosted: Thu Jan 14, 2010 12:04 am Reply with quote
http://www.toolstation.com/shop/Hand+Tools/Plumbers+Tools/Monument+Olive+Removing+Tool+22mm/d10/sd210/p93155
thats the best thing imo. Other than that you can some times ease it off with a pair of grips(don't squeeze it) or hacksaw it as others have said, to save damaging the pipe, just before you saw through put a small flat blade driver in the cut and twist it.
Back to top
 Alert Moderators
fanboy
from United Kingdom
Thanked: 11 times
PostPosted: Thu Jan 14, 2010 12:13 am Reply with quote
junior hacksaw, and when impression is made use a thin flat screwdriver to burst it open to prevent any scraping on copper pipe with hacksaw.
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 131 times
PostPosted: Thu Jan 14, 2010 12:22 am Reply with quote
just to Add when youv scored the olive with the hacksaw blade the use a thin screwdriver to splice it open , got it icon_wink.gif
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 51 times
PostPosted: Thu Jan 14, 2010 12:29 am Reply with quote
The best way to remove it is to tease it off with a pair of water pump pliers!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1089 times
PostPosted: Thu Jan 14, 2010 12:44 pm Reply with quote
you can also nick it with a mini-cutting disk tool like a Dremel
Back to top
 Alert Moderators
gigz
from United Kingdom
Thanked: 94 times
PostPosted: Thu Jan 14, 2010 6:35 pm Reply with quote
Easier if you cut it at 45 (approx icon_wink.gif ) degrees. Is there a degrees sign on a computer ?
Back to top
 Alert Moderators
ScottCheg
from United Kingdom
Thanked: 5 times
PostPosted: Thu Jan 14, 2010 7:08 pm Reply with quote
Is staring at keyboard now gigz..........
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Olive Removal 4 780 Sat Sep 29, 2007 6:29 pm
Removing an Olive from 15mm Chrome Plated Copper Pipe 2 920 Sat Aug 25, 2007 4:57 pm
radiator valve olive 3 560 Mon Jul 30, 2007 8:37 pm
Sealing compound/paste around the olive? 14 2080 Sat Jan 26, 2008 9:42 pm
olive puller's! ..... 15 760 Fri Jul 18, 2008 10:20 am
DIYnot
