DIYnot
Local | Network
   DIYnot > Forums
Local | Network
New ceiling light fitted.....now RCB tripping
Author Message
kevinyork
from United Kingdom
PostPosted: Fri Jan 15, 2010 7:57 pm Reply with quote
Got a new house. Had an electrician install a BIG ceiling light this week and I mean big. Its a 20 x 20w spiral with an inbuilt transformer. Looks superb but a couple of times when turning it on the RCB for that circuit trips. It resets ok but not sure what the problem is. Any advice please?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1087 times
PostPosted: Fri Jan 15, 2010 8:01 pm Reply with quote
RCB is wrong
do you mean MCB?
Or RCD?
What is printed on it?
Back to top
 Alert Moderators
sparkydude
from United Kingdom
Thanked: 22 times
PostPosted: Fri Jan 15, 2010 8:25 pm Reply with quote
Chances are if is a fitting with low voltage lamps and a transformer in it then your electrician has not taken into account the surge on a circuit containing a transformer. Get him back and subject to the maximum EFLI values being acceptable he needs to change the MCB to a C type to overcome this problem. If its the rcd that is tripping chances are he has pinched a cable or something when installing it.
Nick
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Sat Jan 16, 2010 2:17 am Reply with quote
kevinyork wrote:
It resets ok
Who's the regular here with the animated GIF smiley of a dude in a hat slowly shaking his head?
Back to top
 Alert Moderators
sparkydude
from United Kingdom
Thanked: 22 times
PostPosted: Sat Jan 16, 2010 6:26 am Reply with quote
Chances are that as expected Ban all Sheds will give a sarcastic good for nothing unhelpful answer to a question he has no real knowledge about. The OP has not come back to confirm if it is an RCD or MCB yet you jump on the bandwagon AGAIN to criticise the oppinons of a tradesman . Who is to say the rcd is not faulty if it actualy is an RCD. If you cannot post a helpful reply to the OP question may i kindly suggest you keep your sarcasm to yourself.
Back to top
 Alert Moderators
Jacobssi
from United Kingdom
PostPosted: Sat Jan 16, 2010 8:14 am Reply with quote
What is elfi?
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1174 times
PostPosted: Sat Jan 16, 2010 9:17 am Reply with quote
Jacobssi wrote:
What is elfi?
You mean EFLI
Earth Fault Loop Impedance
Back to top
The following user says thank you to PrenticeBoyofDerry for this useful post:
Jacobssi (16 Jan 2010)
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Sat Jan 16, 2010 11:28 am Reply with quote
The OP has not come back to confirm if it is an RCD or MCB yet you have decided, if it is an RCD, to criticise the work of a tradesman.
You, as in "If its the rcd that is tripping chances are he has pinched a cable or something when installing it", rather than "If its the rcd that is tripping chances are that it is faulty".
I'm not sure how helpful your reply was to tell the OP that if it's an RCD that's tripping it's probably due to an intermittent earth fault when you think that the RCD might be faulty.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
ceiling fitted down light kit 2 320 Tue Dec 11, 2007 1:37 pm
FITTED NEW LIGHT AND SWITCH,HIT A PROBLEM 5 660 Tue Jul 10, 2007 9:58 pm
New light fixture fitted (with pics) not working 22 660 Sun May 01, 2011 5:38 pm
Want new CU fitted, will old circuits require updating? 7 740 Thu Jan 10, 2008 2:08 pm
Electrician-fitted part-load consumer unit. 11 1020 Wed Jan 02, 2008 3:01 pm
DIYnot
