DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Small extension - planning permission needed?
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
Author Message
TheRowans
from United Kingdom
Thanked: 1 time
PostPosted: Sat Feb 13, 2010 1:51 pm Reply with quote
Hubby and I have a bit of a budget to stick to for the kitchen/diner conversion we are planning to do in the 1930s mid terrace we have just bough. To make a bit of extra space for the kitchen, we are hoping to extend the old outside loo (now a tiny utility area housing a washing machine and boiler) by squaring it off. Would be app 6m2, in to the centre of the property.
We will of course speak to the planning department once we have moved in, but by looking at the sketch, does anyone know if that is likely to need planning permission? It is not a conservation area, others have done it in the street.
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Sat Feb 13, 2010 2:01 pm Reply with quote
if your property has never been extended in the past then you shouldnt need planning permission but there exceptions.
Back to top
 Alert Moderators
Blagard
from United Kingdom
Thanked: 238 times
PostPosted: Sat Feb 13, 2010 3:17 pm Reply with quote
Have a look at the guide below. In your case an excellent chance it will not be needed.
http://www.planningportal.gov.uk/england/public/buildingwork/projects/workcommonextensionreal/
Back to top
The following user says thank you to Blagard for this useful post:
m2p (13 Mar 2010)
 Alert Moderators
TheRowans
from United Kingdom
Thanked: 1 time
PostPosted: Sat Feb 13, 2010 5:54 pm Reply with quote
Thanks! Will obviously check it out properly once in, but sounds positive then. Would save on planning application costs and the time it would take to apply. The property has never been extended, apart from a loft conversion within permitted development guidelines (dormer loft window).
Hoping to get the complete job including budget kitchen to under 20K.
Back to top
The following user says thank you to TheRowans for this useful post:
m2p (13 Mar 2010)
 Alert Moderators
noseall
from United Kingdom
Thanked: 1294 times
PostPosted: Sat Feb 13, 2010 6:52 pm Reply with quote
You don't live in a conservation area, heritage, outstanding natural beauty, national park, or owt like that do you?
Back to top
 Alert Moderators
TheRowans
from United Kingdom
Thanked: 1 time
PostPosted: Sat Feb 13, 2010 7:14 pm Reply with quote
Nope, it's a bog standard area, no danger of that.
Back to top
 Alert Moderators
jeds
from United Kingdom
Thanked: 448 times
PostPosted: Sun Feb 14, 2010 5:16 pm Reply with quote
In that case it will fall under permitted dvelopment and no planning application is necessary. Don't confuse that with building regulations though. Assuming you intend removing those internal walls - i.e. to make the room one one plan space - You will need to apply for building regs.
Back to top
 Alert Moderators
DOHdesigns
from United Kingdom
Thanked: 214 times
PostPosted: Sun Feb 14, 2010 6:48 pm Reply with quote
Some local authority's welcome pre-application advice free of charge anyway so even still... you could send something like that sketch to them for their comments/approval icon_smile.gif And... if it does fall within PD, you may as well apply for a Certificate of Lawfulness, which would state planning was not required. This would help if you were to be faced with problems down the line (i.e. neighbours reporting potential unauthorised works and if/when you come to sell... even though you have just bought the property) icon_smile.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
Planning permission needed for pitched roofs over small dorm 3 760 Thu Aug 06, 2009 2:04 pm
small extension 5 160 Tue Sep 13, 2011 6:53 pm
Small Extension 4 300 Tue Oct 12, 2010 7:33 pm
Small extension enquiry 13 420 Sun Sep 02, 2012 11:55 am
small load bearing wall 8 1060 Tue May 11, 2010 4:08 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
