DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Timber stud wall with 30min Fire resistance
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
rubberneck
from United Kingdom
PostPosted: Sat Feb 13, 2010 7:06 pm Reply with quote
Hello.
Can I achieve 30 min fire resistance with a stud wall comprising off 75mm timber and a single layer of 9.5mm plasterboard on each side if the cavity is filled with a rockwool type insulation?
Any ideas?
Thanks in advance.
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 287 times
PostPosted: Sat Feb 13, 2010 7:32 pm Reply with quote
Uprate the pb to 12.5mm fireline on both sides and you'll be onto a winner.
I honestly don't why people would bother wilth 9mm plasterboard in any situation.
Back to top
The following user says thank you to Deluks for this useful post:
rubberneck (14 Feb 2010)
 Alert Moderators
noseall
from United Kingdom
Thanked: 852 times
PostPosted: Sat Feb 13, 2010 7:57 pm Reply with quote
Ditto to the above though fireline board is belt and braces.
Regular 12.5mm will give you 30mins f.p.
Back to top
The following user says thank you to noseall for this useful post:
 Alert Moderators
rubberneck
from United Kingdom
PostPosted: Sun Feb 14, 2010 9:37 am Reply with quote
Thanks for those replies. I've decided to put an additional layer of 9.5mm on either side of the stud wall instead. Hopefully this will aid with sound deadening as well.
Thanks again.
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Sun Feb 14, 2010 10:27 am Reply with quote
why not just use 1/15mm plasterboard and save on screws and time.
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1174 times
PostPosted: Sun Feb 14, 2010 12:05 pm Reply with quote
Double boarding is fine but must agree with the above replys.
12.5mm plasterboards are the normal these days, 9.5mm not really used that much now by the pro, but it does have a minimum of 30mins fire resistance, whether plastered or unplastered, it's not something I'd recommend though.
Back to top
 Alert Moderators
Master of None
from United Kingdom
Thanked: 15 times
PostPosted: Sun Feb 14, 2010 1:01 pm Reply with quote
Also ant penetrations for cables and pipes will need to be dealt with correctly. Ie. fire stop, pipe collars etc.
Ps not that familiar with domestic situations.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Timber stud as a fire wall? 6 660 Fri Feb 27, 2009 7:33 pm
Installing an open fire into a timber lined wall?? 5 200 Mon Nov 22, 2010 10:11 pm
Fire Resistant Stud Wall 6 1460 Wed Jan 16, 2008 12:33 pm
Adding a gas fire and flue to a timber frame hse 4 800 Thu Nov 22, 2007 9:55 pm
Stud wall timber size 11 2540 Thu Jan 06, 2011 6:19 pm
DIYnot
