DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wiring Smeg hob SE2640TC
Author Message
zlatankov
from United Kingdom
PostPosted: Mon Mar 15, 2010 10:59 pm Reply with quote
Hi, can anyone help me with this one?
I have an electric Smeg ceramic hob, model SE2640TC, and I need to connect it to the mains via a terminal which has four points plus one for earth. I have a diagram showing how to connect the mains (yellow wire to the grounds port on the terminal, live wire to interconnected 1-2-3 and neutral to the port 4). The problem the wires coming out of the hob (one brown, one purple, one red and two white wires joint in one) are not connected to the terminal and I have no diagram indicating how to map the internal wires to the mains wires. Can anyone help?
Back to top
 Alert Moderators
skenk
from United Kingdom
Thanked: 49 times
PostPosted: Mon Mar 15, 2010 11:20 pm Reply with quote
There are loose internal wires? icon_confused.gif Take it back to the shop for a replacement!
Normally a hob is connected in the way you describe with a cable which is not supplied with the appliance. You should not have to do anything with internal wires.
A picture would help
Back to top
 Alert Moderators
zlatankov
from United Kingdom
PostPosted: Tue Mar 16, 2010 8:44 am Reply with quote
I am at work now, will post a picture this evening.
The hob is not new (i.e. it's been used) so I can't take it back. Unfortunately the terminal was taken off so I can't tell any more which internal wire was connected to which terminal (except that the red internal wire was going to the first port which was not connected to any of the mains wires??).
Back to top
 Alert Moderators
zlatankov
from United Kingdom
PostPosted: Wed Mar 17, 2010 1:53 pm Reply with quote
Hi, here is the actual picture:
You can see the internal wires and the terminal. On the terminal, from left to right , ports are as follows: , #1, #2 and #3 are for live; #4 for neutral; #5 for ground.
But I can't work out where to connect the internal wires (purple, two withe wires connected into one, brown and red).
Can anyone help?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 720 times
PostPosted: Wed Mar 17, 2010 5:06 pm Reply with quote
If this is new oven, tell the shop to get you a new one.
That one has been messed about with.
Is it new, or is it a second hand special?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Wed Mar 17, 2010 5:18 pm Reply with quote
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 720 times
PostPosted: Wed Mar 17, 2010 6:27 pm Reply with quote
Well, electricians do not really deal with appliances.
You could try and ask on the Appliances forum, but you will be better off asking here: http://www.smeg-service.co.uk/
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
wiring a smeg hob (safely) 8 1020 Sat Dec 24, 2005 11:00 am
SMEG Cooker - Circuit Wiring 5 780 Sun Mar 04, 2007 8:31 pm
wiring an A42A Smeg Cooker 8 300 Fri Nov 12, 2010 4:04 pm
SMEG and 13AMP 15 5900 Mon Mar 15, 2004 9:26 am
FITTING NEFF OVEN & SMEG HOB 2 980 Thu Dec 09, 2004 1:38 pm
DIYnot
