DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Friend's electric Mira shower loosing pressure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Min
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 28, 2005 10:03 am Reply with quote
My friend reckons that his Mira electric shower is losing pressure because it is getting furred up with hard water.
I suggested he contact a plumber who can either service it or replace it with a new one. (Can it be worth it to descale a shower unit??) He won't listen to my advice and thinks he can pour descaler into it, the only thing stopping him is the fact that the inlet from the CW is on the underside.
When you lot have stopped laughing, perhaps you could advise.....
Thanks folks
Min
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Mon Feb 28, 2005 10:07 am Reply with quote
Back to top
 Alert Moderators
Min
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 28, 2005 10:21 am Reply with quote
whether there is some way of descaling the unit or servicing it, or whether it must be replaced.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Mon Feb 28, 2005 10:40 am Reply with quote
Try descaling/ replacing the shower head first. icon_biggrin.gif
Back to top
 Alert Moderators
Min
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 28, 2005 11:01 am Reply with quote
Thanks Bahco, he's descaled the head (sorry for not mentioning it) so I'll tell him to get a new shower unit.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Feb 28, 2005 11:03 am Reply with quote
you can descale the heater can but it usually goes BANG afterwards icon_cry.gif
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 2 times
PostPosted: Mon Feb 28, 2005 11:08 am Reply with quote
How does he know that the problem is in the shower? The words "keeps losing pressure" suggests something that comes and goes and that doesn't sound like scale buildup. Tell him to try turning on the kitchen cold tap and see what it does to the shower. If it causes the pressure loss he's getting then the problem lies in the mains supply somewhere upstream of both tap and shower.
Does the shower have a reduced power setting and a thermostat? If so then another possibility is intermittent loss of power to one of the heating elements. The thermostat will respond to this by reducing the flow.
Back to top
 Alert Moderators
Min
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 28, 2005 11:21 am Reply with quote
Felix - it doesn't 'keep' losing power, it is losing power progressively as the weeks go by.
Kev - thanks, good to hear my suspcicions confirmed. I told him that the heat exchanger (if thats what you call it) wouldn't take too kindly to the rigours of descaling.[/quote]
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 2 times
PostPosted: Mon Feb 28, 2005 9:42 pm Reply with quote
some electric showers have a little gauze filter at the inlet pipe fitting. Might be worth checking this for debris. icon_question.gif
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 01, 2005 11:13 am Reply with quote
Sorry, I misread the original post. A progressive loss of flow means that something is slowly blocking up. It could be a filter like brumylad says. It could also be the shower head itself. Our conventional mixer shower needs its head cleaning out once or twice a year.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1119 times
PostPosted: Tue Mar 01, 2005 11:46 am Reply with quote
It could also be because the water mains is getting COLDER! So he has to turn the flow down to get the temperature up further than before.
Electric showers only piddle at about 4 litres/min so flow shouldn't be a problem. It's dead easy to check - if he turns the temp down does the flow rate go up???
Tell him it'll be better in the spring!
Back to top
 Alert Moderators
Min
from United Kingdom
Thanked: 1 time
PostPosted: Tue Mar 01, 2005 2:05 pm Reply with quote
I love you guys!
Thanks.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
my friend has asked me to move radiator why he plasters 3 580 Wed Nov 16, 2005 3:39 pm
Recommend a friend?? 4 460 Fri Aug 07, 2009 12:04 pm
Called to help a friend and I think I uncovered a gas leak 2 120 Fri Oct 05, 2012 8:17 pm
Honeywell ST7100 - farewell to an old friend? 2 3880 Tue Dec 16, 2008 5:53 pm
Sealed System Loosing Pressure with no leaks visible 10 1300 Wed Jan 21, 2009 5:39 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
