I have the above mentioned CP61 pump installed in a Potterton Puma 100e boiler and I am not sure whether it is working correctly. Radiators closest the pump seem to be very warm those furthest away less so. Radiators have been bled, TRV pins freed,etc so problem seems to be maybe more pump/sys related. I've tried to check whether the pump is working correctly but am not sure if I am checking the right thing as per the user guide. One interesting point is that sometimes the system works fine(and all radiators heat up to a certain extent)other times it just seems to stop.
When I turned the black hexagonal nut on the pump it came away(it's plastic) and there is a screw behind it. I have twisted this and some fluid comes out...should I twist the screw the entire way out to check if there is maybe a problem behind it or not? If so then what do I need to check?
Also, on the Potterton should the green flame light be lit all the time the CH/HW system is on or not(it seems to click on and off from time to time).
Thanks for any help in advance.
