Ign cycling
6 Mar 2005
Boiler is Sime Friendly Format (Combi)
Problem is boiler lights then goes out then lights and so on, radiators get nice and warm; water is not as hot as it used to be.
Changed thermocoulple, thermistor, limit sensor, overheat sensor, and frost stat, checked air switch, anyone got any ideas.
Yep, Find out how the boiler works and stop guessing!
How much £ have you spent!?
How long does it stay alight and is it the same on HW as CH?
Yes, it's the same on HW and CH, however I have noticed the fault disappears when lit from cold, once it has warmed up the cycling begins.
I have now noticed the boiler works perfectly when the time kicks in in the morning that is until I use the hot water then the cycling begins. Could this be a fault with the diverter valve?
Thanks in advance.
