Radial circuit
1 May 2010
Can i run a 2.5mm cable on a radial circuit from a 16amp on the C/U to a socket that in turn will operate a 3kw oven and ignition for gas hob?? Cable run will be 10mtrs and it will be under floor.
Will i need to use an isolation switch or is it not necessary?
