DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Laminated flooring!
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Chantale
from United Kingdom
PostPosted: Wed Mar 26, 2003 3:40 pm Reply with quote
I have set myself a challenge to put down some laminated flooring in the spare bedroom! 8x11 mts, this week end, yes I know fool....that I am!
Would you be kind enough to advise with some dos and don'ts, some of you must have played this game before. icon_rolleyes.gif icon_rolleyes.gif
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 115 times
PostPosted: Wed Mar 26, 2003 9:11 pm Reply with quote
Try and visit a B&Q Warehouse before you start, They have a leaflet that seems to cover every aspect
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 98 times
PostPosted: Wed Mar 26, 2003 9:18 pm Reply with quote
If the laminated flooring is the glue type where you have to join it together,I found the best way is to glue it on the tongue on both side instead of the groove side which the manufacter recommend.I found its join better at the tongue side as there's no airlock this way.If you put the glue on the groove side I find it hard to push the air & glue out.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 76 times
PostPosted: Fri Mar 28, 2003 2:33 am Reply with quote
Get yourself a Laminate Floor Fixing Kit.They are about £8 and make the job much easier.It consists of a knocking block with grooves in and a flat bar bent in opposing directions at each end. This is to slot in at the perimeters and pull the boards together.Also don't forget to leave an expansion gap of 10-12mm all around.If you are using the Scotia or Quadrant trim then stick it to the skirting and not the floor because any movement of the floor may push it into the skirting and knock it off.Hope this helps you.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 76 times
PostPosted: Fri Mar 28, 2003 7:57 pm Reply with quote
By the way how big is your main bedroom if your spare is 8m X 11m ????
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 98 times
PostPosted: Fri Mar 28, 2003 8:26 pm Reply with quote
I think he meant 8 miles x 11 miles !!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
How to finish around belfast sink in laminated worktop 4 540 Tue Mar 29, 2011 10:07 pm
sealing laminated splashback 4 960 Sun Jun 27, 2004 5:44 pm
Linseed oil stains on laminate flooring. 2 500 Sun May 04, 2008 8:15 pm
Fireplace fitting - can I put hearth on oak flooring? 5 1880 Thu Jan 11, 2007 10:44 pm
Removing vinyl flooring adhesive 2 1280 Sun Sep 05, 2004 12:38 am
DIYnot
