Hi hopefully someone can help me.
In my bathroom (which is seperate to my toilet) in my flat I had a pull light switch, this used to turn the bathroom light and the fanon at the same time when pulled. The toilet room next door to it has a flick switch which turns the light on in the toilet and the fan (fan duct runs from bathroom fan to toilet) at the same time.
The pull switch in the bathroom stopped pulling so a friend removed it and discovered that one of the contact plates inside the block had snapped.
So off I went to shops and brought exactly the same pull switch (double pole).
Now because my friend removed the old pull switch i cant remember which wires go where on the block!
Images attached of wiring and block.
Am unsure of where to place the two reds and 2 blacks, the green earth is fine as is already in situ.
Moogie
View media item 24652 View media item 24653 View media item 24654
Moogie
