DIYnot
Local | Network
   DIYnot > Forums
Local | Network
GAS HOB IGNITION WONT STOP FIRING
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Bondai
from United Kingdom
PostPosted: Wed Aug 04, 2010 11:24 pm Reply with quote
ELECTROLUX GAS HOB
MODEL: EHG641
Hello
My gas hob wont stop firing when power is turned on. All x4 poles are constantly sparking as soon as the power to the hob is on.
Is anyone familiar with this ? can you advise on what to do next in order to solve this problem.
Any advice most appreciated
Thank you
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 198 times
PostPosted: Thu Aug 05, 2010 6:51 am Reply with quote
Is this the type that has a separate ignitor button? If so disconnect it & if the problem stops then you probably have water in the switch, if it is the type that automatically ignites when you turn on the gas then it would seem that the control unit is faulty.
Back to top
 Alert Moderators
Bondai
from United Kingdom
PostPosted: Thu Aug 05, 2010 5:23 pm Reply with quote
Hi thanks for replying
Well no its not separate. The ignition spark is usually activated by pushing the gas 'knobs' in whilst turning. You push whichever gas 'knob' in and turn at same time to let the gas flow, according to which gas ring you want to fire up.[/b]
PROBLEM SOLVED
One of the gas knobs had some greese built up inside it which was causing the built in ignition to stick. I removed the knob and cleaned the part it slots on to (this is the actual part that the outer knob slots onto and is turned and pressed down by the knob)
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 198 times
PostPosted: Fri Aug 06, 2010 6:22 am Reply with quote
Back to top
 Alert Moderators
TrixieC
from New Zealand
PostPosted: Fri Mar 09, 2012 11:41 pm Reply with quote
Thank you for this! I cleaned underneath all knobs and the problem is fixed! Didn't have to call out a serviceman after all, and has saved me about $120! icon_smile.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Ariston Cooker - Piezo Button Permanently Firing! 5 920 Fri Sep 07, 2007 10:00 pm
Neff Gas Cooker Ignition Won't Stop Operating 2 1820 Tue Jun 08, 2010 12:22 pm
will my mains automatic ignition gas cooker work in a power 5 1240 Sat Aug 21, 2010 11:24 am
CREDA GAS HOB - NO IGNITION ? 4 300 Tue Oct 26, 2010 9:48 am
Hob Gas Ignition 3 760 Fri Sep 11, 2009 3:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
