Connecting Electric oven via a 13amp plug
16 Aug 2010
Kent
During the installation of my new kitchen the electrician replaced the old connection behind the oven with a socket and connected a 13amp plug to the cooker so it could just be 'plugged in'. He insists that this is safe for a modern electric single oven. Is he correct?
Usually yes. Most single ovens are low enough power to be fed from a 13A socket and using a 13A plug provides overcurrent protection for the relatively small flex to the oven.
I'm not so sure - an awful lot of ovens these days are designed with the expectation of a 16A supply.
But 'tis simple to resolve. Smiggal, what's the rating in watts of the oven?
I just checked on the Bosch website and it seems the oven is rated at 16A. Does this mean I will have a problem because the electrician has plugged it in using a 13A plug? More to the point - is it dangerous???
providing your plug contains a 13 amp fuse it cannot be dangerouse just inconveniant
You could well have problems. At 16A a 13A fuse will never blow, but the plug and/or socket could overheat.
I seriously question the competence of your electrician if he took an appliance where the maker says it needs a 16A circuit and he put it on a 13A one.
It's connected to the dedicated cooker circuit, but via a 13A plug. I think I need to get it changed...
Good luck.
Bosch are one of the worst offenders for not considering the differences between UK installations and the rest of Europe.
16A means 16A, so you won't be able to connect it to the cooker circuit - you'll need a new 16A circuit put in, or a small enclosure with a 16A breaker supplied from the cooker circuit.
It's already plugged in to the dedicated cooker circuit, there is nothing else connected to that circuit on the CU.
If it really is a dedicated circuit then it's probably already on at least a 16A MCB. If you can confirm this, it shouldn't be a problem to change the 13A socket for a cooker connection plate. Pictures would help...
