DIYnot
Local | Network
   DIYnot > Forums
Local | Network
volume control on tv
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual
Author Message
doronsky
from United Kingdom
PostPosted: Tue Oct 05, 2010 6:17 pm Reply with quote
its not varied enough on control, cant turn it down to a whisper .
its a neon 32 lcd
can i put a potentiometer on the tele my self. don't no what's in side
as i haven't had a look as yet . how do i wire one up .
two speakers with one red and one black on each speaker is what i would expect to find , if the back is off . 3 pins on the potentiometer . and still keep stereo sound . any diagrams please it should be easy to do this without taking it to tv repair shop . as its only the speaker cables .
i think i should be able to use 1 potentiometer for the 2 speakers ??
i realise electricity will be held in some components and care must be taken
thanks ron
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 277 times
PostPosted: Tue Oct 05, 2010 8:42 pm Reply with quote
are you running sky through it?
if so perhaps you can set the volume in the sky box lower then the tv,
Back to top
 Alert Moderators
doronsky
from United Kingdom
PostPosted: Tue Oct 05, 2010 10:11 pm Reply with quote
no sky .
just the built in freeview is used & there's no headphone socket on this television so i cant do outside speakers
Back to top
 Alert Moderators
pellow
from United Kingdom
Thanked: 2 times
PostPosted: Wed Oct 06, 2010 12:27 pm Reply with quote
You cannot attach a potentiometer to the speaker cables. You will alter the impedance of the speaker circuit and may seriously overload the audio output IC causing it to overheat and fail. Volume control is done nowadays by digital increments with + and - buttons or via remote. The circuit cannot be altered.
Back to top
The following user says thank you to pellow for this useful post:
doronsky (6 Oct 2010)
 Alert Moderators
doronsky
from United Kingdom
PostPosted: Wed Oct 06, 2010 1:27 pm Reply with quote
i decided to change teles from the spare room to the main room its a lot easier as volume levels don't mater in this room as it is end of semi detached and there is better control of the volume on the spare tele that was used for gaming . best i leave it alone with the volume idea .thanks for the info i learnt something today i prefer the other tv but needs must
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual All times are GMT
Page 1 of 1
Jump to:
Sky remote - volume control 8 600 Fri Oct 22, 2010 11:49 am
Better headphone volume. 7 160 Mon Feb 20, 2012 3:39 am
philips 42" tv volume problem 9 160 Sat Jan 14, 2012 10:15 am
Roberts Rd-50 DAB Radio Sound/Volume Issue 12 160 Sun Mar 31, 2013 11:43 am
volume on remote not working 5 240 Sat Dec 18, 2010 10:29 pm
DIYnot
