Hi all,
first post here. Hopefuly I wont go down in flames for asking an electrical question
I am rennovating my kitchen at the moment and I would like to install a new ring main for the sockets I will add. My current CU has run out of space and so I would like to add a small 4 or 6 way unit as an addition rather than replace the whole unit.
My question is this:
As the existing CU is protected by an RCD can I in theory remove one of my ring mains from the existing unit and add an higher rated MCB to connect to the existing unit to the 100A isolator in the secondary unit?
I would then have 2 ring mains running in the secondary unit.
What rating of MCB would I requir in the primary unit?
Would the secondary CU be protected by the RCD in the primary?
Would 10mm T&E be sufficient to connect the primary to the secondary?
Hope that makes sense!
Look forward to hearing from you.
Tim
Tim
