Hi guys, I have been on here quite a few times and just decided to join tonight so I can ask some advice on the above.
I used to have a solid fuel fire with back boiler supplying my radiators in my house, and a good heat they supplied as well but a bit messy, and a bit of a pain running in and out for anthracite in the middle of winter. Anyway a few years ago I done away with this system, plastering up the wall taking my hearth away and installing a combi gas boiler. Recently I even emptied the tank in the loft and disconnected all the pipes to take the tank down but couldn't get it down through the hatch. I still have the small open tank with a ballcock, and a pipe going outside to my flat roof, which I take it this is a vented system?
I have been thinking of combining a wood burner with my combi for a while, and was thinking of building a small room on my outside wall, at the opposite side of the outside wall to my gas boiler. I was thinking of having all the necessary tanks and vents etc housed in the little room my wood burner would be in. The reason behind this is keeping the mess outside the house. I have since been thinking it would be a bit of a waste loosing all the heat produced by the wood burner itself heating a small room that no one will be in, and am thinking of having it in the house where the solid fuel burner was previously.
My questions are, without having the hearth can I just sit the wood burner on a concrete slab on top of my laminate flooring? and use the chimney I already have, it is a single storey building, would I need a liner all the way up the chimney? Would the wood burner heat the tank I already have and simply have the water from the combi pass through the tank to preheat before going into the combi?
Before someone says get an expert, I have tried on numerous occasions to get help with this and no one seems interested as soon as you mention gas combi and wood burner.
Thanks in advance for any help or advice.
Peter
Peter
