DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Bosch GREENSTAR 30SI water pressure problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
TonyUK1
from United Kingdom
PostPosted: Fri Oct 22, 2010 11:42 am Reply with quote
Hi All,
Can anyone help. The water prssure gauge on my Greenstar 30Si continually goes to 0 prressure whenever the central heating stops. I've had the RCI installer return 2 times and he doesn't seem to be able to solve the problem. I am on normal water supply - Severn Trent in Birmingham. One time the Installer bled the system and introduced a sealant - that has not worked. He thought one of the rad may have a leak - they were all sound. Anyway if that was the case surely the sytem would run dry during operation.
Anyone got any clues about what it could be - is there an issue inside the boiler mechansim and valve which could be causing the issue.
Back to top
 Alert Moderators
barryauid
from United Kingdom
Thanked: 14 times
PostPosted: Fri Oct 22, 2010 3:11 pm Reply with quote
If you put pressure in the boiler to say 1bar and you put the heating on is the gauge going unto 3bar? You should then notice the copper pipe which is connecterd to the safety valve and goes outside will probably be dripping if so then the expansion vessel will either need recharging or replacing!
Back to top
The following user says thank you to barryauid for this useful post:
TonyUK1 (25 Oct 2010)
 Alert Moderators
TonyUK1
from United Kingdom
PostPosted: Mon Oct 25, 2010 7:33 am Reply with quote
Thanks Barry - I tried what you said putting the pressure to 1bar - and sure enough when the heating fired up it moved up to 3 Bar and went above that, then started to make various noises. Outside the copper exit pipe was dripping.
If I get an engineer iand ask them to replace it - whats the correct terminology to get them to do it - and what would be your estimation of the cost?
Cheers
Tony
Back to top
 Alert Moderators
plumbersmate1
from United Kingdom
Thanked: 2 times
PostPosted: Mon Oct 25, 2010 8:04 am Reply with quote
Take the little air cap off the expansion vessel and press the little pin in, if there is water in there it is definately split. If you get nothing, then it may just need repressurising.
Back to top
The following user says thank you to plumbersmate1 for this useful post:
TonyUK1 (26 Oct 2010)
 Alert Moderators
barryauid
from United Kingdom
Thanked: 14 times
PostPosted: Mon Oct 25, 2010 2:31 pm Reply with quote
As above the vessel is accessed at the back of the boiler and over the top near the flue. The pin is a schrider valve which is the same as the one on a bike inner tube.
See the FAQs at the top of the plumbing and heating, ChrisR explains it very well. icon_wink.gif
As for cost it would depend if it needs recharging or replacing! icon_rolleyes.gif
Back to top
 Alert Moderators
TonyUK1
from United Kingdom
PostPosted: Tue Oct 26, 2010 3:52 pm Reply with quote
Thanks to both above - very helpful. If the vessel is faulty could this be a major job for the engineer. Just trying to get an idea on costs. Because I would prefer to get a qualified heating /plumbing engineer in to do the work. Any suggestions for around the Birmingham area?
Tony
Back to top
 Alert Moderators
tontowales
from United Kingdom
PostPosted: Tue Nov 16, 2010 6:17 pm Reply with quote
i have a powermax 155x 2002 and recently the water pressure dropped to 0 after using hot water..if i re pressurise up to 1.5-2 it just repeats and the red light lockout comes on.
ive had 3 peeps out and not the solution yet..could be a leak,or re pressurise or aav or prv but im a total novice and would be grateful for any help or if anyone is near cardiff am happy to offer the work out.
thanks
Back to top
 Alert Moderators
arronack
from United Kingdom
PostPosted: Thu Dec 06, 2012 10:51 pm Reply with quote
Hi everyone.
I have exactly the same problem with the same boiler. I'm fed up of filling it up every morning before the heating kicks in. Did anyone manage to find a solution, or figure out if it was the expansion valve?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3427 times
PostPosted: Thu Dec 06, 2012 10:54 pm Reply with quote
They would have done if they had read the FAQs and followed the procedure correctly!
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Greenstar 30si DHW problems 5 220 Wed Dec 29, 2010 12:30 pm
Weaping pressure relief valve - Worcester greenstar 30si 6 320 Sat Dec 01, 2012 8:07 pm
Worcester Greenstar 30si - no central heating water 6 160 Thu Sep 19, 2013 9:48 pm
worcester greenstar 30si combi boiler no hot water 2 140 Thu Oct 30, 2014 5:41 pm
Worcester Greenstar 30Si - intermittent hot water 2 60 Sat Jun 30, 2012 7:23 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
