Regarding the use of Choc Boxes, are these a requirement of the Building Regs? In other words, are you not allowed now to just use block connectors as insulated connections?http://www.tlc-direct.co.uk/Products/CHOCBOX.html
Choc block and insulation tape does not provide any strain relief for the cables.
Choc boxes have a clamp to prevent the cables being pulled out of their terminations. This is a BS7671 requirement.
Funny that, as Regulation 207 (H) of the 13th Edition says, "Cores of sheathed cables from which the sheath has been removed and non-sheathed cables at the termination of conduit or duct or trunking shall be enclosed. The enclosure shall be of incombustible material and may be a box complying with BS 816 or other appropriate British Standard, or an accessory or lighting fitting."
There are two reasons for enclosing terminations. The one most people think about is protection from electric shock, but equally important is prevention of fire.
(And prevention of fire is how the Regulations came about in the first place.)
The choc box is an easy way of enclosing a choc block to meet both of those fundamental requirements.
