Hi all,
Wonder if I could ask some advice.
We have a Biasi Riva Compact HE gas boiler here that's suddenly decided to start started playing up.
The three flashing lights on the front are showing the error :
"Lack of burner ignition (no ignition signal from the full sequence ignition device)"
I'm not really up on boilers but it kind of sounds like some sort of sensor issue which isn't returning data..
When the lights are flashing the "lockout signal lamp" lights up on the front of the boiler which seems to indicate the boiler's intentionally shut itself off as a safety measure. I can then press the "lockout reset button" to turn off the lockout lamp which then causes the boiler to burst into life - blue flames, ignition, everything! But then a few seconds later it shuts itself off again. =(
Currently not hot water, no heating, anyone any ideas what the likely cause is?
I'm thinking this this going to be an expensive call out. =(
