DIYnot
Local | Network
   DIYnot > Forums
Local | Network
BOULTER CAMRAY 3 BOILER RELUCTANT TO START UP
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
altimeter
from United Kingdom
PostPosted: Sat Dec 04, 2010 5:58 pm Reply with quote
Hi you experts, I have a 15 year old camray 3 boiler with a new reillo 40 burner unit fitted recenty as the old one was knackered on too many counts. About one time in 3 the burner does not start up and run cleanly for its 12 secs to light up, but makes several noises as if the electrical power is not getting through to the motor when it first starts up. The same thing happened with the old burner (not why it was changed), so I am assuming it is not the fault of my new burner. IN all other respects the system runs fine lights up OK and runs very smoothly and quietly. Could it be that the control stat is getting old and is not switching over cleanly? I have a new one I got as a precaution a year ago when this problem started- is it time to fit this to cure the fault, is it a difficult job please, or might it be something else?
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 341 times
PostPosted: Sat Dec 04, 2010 6:18 pm Reply with quote
If you have a stat,it would be the obvious next step.
10 minute job. 4 self tappers and two spade terminals.
Back to top
The following user says thank you to Terrywookfit for this useful post:
altimeter (4 Dec 2010)
 Alert Moderators
altimeter
from United Kingdom
PostPosted: Sat Dec 04, 2010 6:39 pm Reply with quote
many thanks, I will change the unit over
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 341 times
PostPosted: Sat Dec 04, 2010 6:42 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Reluctant Boiler! 2 280 Fri Dec 14, 2007 1:30 pm
Housewarmer 55 on LPG - boiler reluctant to fire when warm. 2 220 Thu Mar 20, 2008 7:36 pm
Reluctant Central Heating - Apollo Fanfare 6 480 Tue Jan 23, 2007 11:46 pm
One reluctant rad 6 300 Mon Mar 21, 2005 8:52 am
Boulter Camray 15/21 external oil boiler 3 40 Tue May 15, 2012 11:14 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
