DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wiring wireless room stat into Combi boiler
Author Message
thomo2710
from United Kingdom
PostPosted: Tue Dec 14, 2010 9:21 am Reply with quote
Hi all,
Could somebody please help me understand the following diagrams on wiring my new room stat into my boiler.
Boiler - Vaillant Turbomax Pro 24e
Stat - Honeywell CMT927 Wireless
Boiler wiring:
Page 17 of the following PDF link
http://neighbourconstructions.co.uk/...stallation.pdf
Stat wiring:
Page 7 of the following PDF link
http://www.plumbnation.co.uk/site/ho...cification.pdf
Currently the boiler has a loop wire in pin 3 + 4 for the plug in vaillant timer. I know i havre to take this out.
T1 and T2 are pin 3 and 4? Assuming looking at page 18 of the vaillant PDF
I dont know what that 10a fuse is for and where the diagram goes off too towards the left.
Boiler is currently hooked up to the mains supply via a fused spur.
The reciever unit is powered off a switched live.
My friend is confident he can do it as he is fairly competant with doing electrics but i want to clarify 100% what goes where first as he doesnt want to go ahead for deffo and turn the boiler back on with a bang before we are 100% certain what goes where.
Thanks in advance.
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Tue Dec 14, 2010 9:43 am Reply with quote
ok so having another look over it am i anywhere close?
2 cables
1st cable - core 1 in pin 3 (T1) to A and core 2 in pin 4 (T2) to B
2nd cable - core 1 piggybacked into the L on the boiler board to L and core 2 piggybacked into N on the boiler board to N
The 10a fuse is what should be in the fused spur socket?
How close am I?
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Tue Dec 14, 2010 10:01 am Reply with quote
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Tue Dec 14, 2010 10:08 am Reply with quote
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Tue Dec 14, 2010 10:43 am Reply with quote
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Tue Dec 14, 2010 10:55 am Reply with quote
holmslaw wrote:
You want drawing b on page 7 of the Honeywell manual.
T1 and T2 are the same as 3 and 4 on your boiler.
And you need a 3 Amp fuse not a 10Amp.
Thanks man, ill check what fuse is in the spur already at lunch time.
But apart from that am i there with what i put in post 2?
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Tue Dec 14, 2010 11:15 am Reply with quote
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Tue Dec 14, 2010 11:20 am Reply with quote
Diagram B on Page 7 of the Honeywell manual.
A on stat to T1 (3 on boiler)
B on stat to T2 (4 on boiler)
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Tue Dec 14, 2010 11:40 am Reply with quote
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Mon Dec 20, 2010 8:09 pm Reply with quote
Re: Help wiring Honeywell CMT927 roomstat into Combi boiler
Hey me again
Sorry to be a pain..... I'm doing this tonight and I want to get it 200% right as it's not exactly the weather to be without a boiler.
N L L on the relay box.
Boiler is run off a switched spur.
N on relay box - do I tap into the N on the boiler pcb and run the other end into the N bank on relay box.
Middle L - tap into L on spur socket to Middle L on relay box?
Right side L - single core cable from that straight to L on boiler pcb?
Picture on install only shows 2 wires - 1 in N and other in rightbside L
Thanks in advance
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 149 times
PostPosted: Mon Dec 20, 2010 9:11 pm Reply with quote
Ignore the middle L terminal on the receiver.
It needs a Live and Neutral, you can get this from the spur, or from the PCB, makes no odds.
Back to top
 Alert Moderators
Marco1976
from United Kingdom
PostPosted: Tue Dec 21, 2010 11:23 am Reply with quote
sorry to hijack the post but i have a similar problem.
Does the Live in the relay box need to be connected to another terminal within the receiver?
Back to top
 Alert Moderators
thomo2710
from United Kingdom
PostPosted: Tue Dec 21, 2010 8:34 pm Reply with quote
I got mine working with:
N in relay box to N on fused spur socket
Right hand side L in relay to L on fused spur socket
Left middle L in relay box empty.
Also use 1.5mm cable as the relay box terminals will not accept 2.5mm cable as I found out!!
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 149 times
PostPosted: Tue Dec 21, 2010 9:26 pm Reply with quote
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Wireless room stat wiring problems 2 440 Sun Nov 25, 2007 9:12 pm
recommendation for a wireless room stat 24 300 Tue Feb 26, 2013 7:13 pm
Replacing honeywell T40(T6360B) thermostat for wireless stat 19 200 Mon Jan 14, 2013 6:37 pm
wireless stat 7 220 Sat Feb 05, 2011 12:06 pm
Replacing a Drayton Combi-Stat RTS8 with a Horstmann HRT4-ZW 2 60 Sat Mar 02, 2013 10:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
