Does anyone know where I can source a heavy duty drain / gully cover? It's for commercial use (heavy cages being dragged across it). Plastic / Cast Iron ones don't last 5 minutes.
don't know, but i once had my local steel shop cut me some squares of 8mm plate, which i then drilled with a press drill for drainage
they're still in use today best part of 15 years on.........
