DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Indesit Oven FI 31 KB IX will not come on
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
npaisnel
from United Kingdom
PostPosted: Wed Feb 16, 2011 2:41 pm Reply with quote
Two days ago the cooker would not come on and so far have been unable to find the cause.
It is powered through the same wall switch as the hob...and the hob works fine.
There is mains power into the unit and if I bypass the thermo switch that runs the cooling fan (not internal oven convection fan) then that cooling fan starts up.
When I turn the function selector switch into the oven position or grill position..nothing happens..no light neon, fan ...nothing. Both elements have infinite resistance to ground ( not shorted to earth) and both have 30Ω or so between terminals..so elements seem to check out.
No contacts seem to be burned in any way
Thermo switch in back of oven is showing continuinity
What is going on here?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Wed Feb 16, 2011 2:50 pm Reply with quote
Does it have a timer/clock?..is it set to manual?
Back to top
 Alert Moderators
npaisnel
from United Kingdom
PostPosted: Wed Feb 16, 2011 3:50 pm Reply with quote
No, nothing as simple as that...there is a simple clockwork time reminder...but no electrical connection it is just a clockwork 'egg timer' that rings a bell
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Wed Feb 16, 2011 3:56 pm Reply with quote
I can only think that the selector switch is faulty or there is no live connection to the selector switch.
Back to top
 Alert Moderators
npaisnel
from United Kingdom
PostPosted: Wed Feb 16, 2011 4:08 pm Reply with quote
Selector switch maybe...but there is live power into the selector switch, AND out the other side, to the element and light,
There is voltage on both ends of the element,,so it is not connecting to neutral somewhere, So mains voltage both ends of the element and back up the wiring back to the switch..
I can trace back to the selector, but then ....not sure...It is all buttoned up again and back in the unit for now.
Possibly something on the neutral side, but it affects everything except for the cooling fan which is on it own circuit, separate from the selector switch.
No grill, no light, no convection fan or heat element, but cooling fan which is single circuit from live in, through a thermoswitch and back to Neutral out...works fine.
So yes it does point to the selector switch...but nothing appears wrong with it...no burnt plastic, all contacts look clean.
I have removed it, labeled up the wires, given a blast with leccy contact cleaner spray and re asembled...still no joy.
So possibly something on the switch that has sheared clean off and dissapeared??? But all terminals that are connected do make/break to at least some of the others as the selector is rotated.
If I could find the correct switching sequence, then I would stand a chance
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Indesit FX31K Oven Thermostat 2 120 Tue Nov 30, 2010 2:39 pm
Indesit FID20 built-in oven 3 80 Sat Jul 09, 2011 7:31 am
Internal wiring of an Indesit FID20IX oven 7 320 Wed Oct 06, 2010 7:13 pm
Indesit electric oven wont turn on 4 60 Thu Jul 07, 2011 4:15 pm
indesit double oven FIU20IX 9 480 Sun Jul 04, 2010 7:59 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
