DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
damaged door
This topic originated from the How to page called Replacing internal doors
Click here to return to the page called Replacing internal doors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
greenwin
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 26, 2005 5:38 pm    Post Subject:
damaged door
Reply with quote Thanks
I have a 10 year old hollow door with a hole in it. As it is basically a cheap door I was gong to replace it but cannot find one that matches the others. Is it possible to repair the hole ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Thu May 26, 2005 6:10 pm    Post Subject:
take a bit off wood[6mm ply] 2"bigger than the hole screw a screw in the centre as a handle
place no nails or simmilar on the overlap area manoover with the screw into position pull forward against the inside edge to form a sunken lid
when dry remove screw and fill
or alternativly pad out the hole with paper till you have a small 6mm ledge all the way round behind the pannel and at least 10mm deep hole
fill up the hole in two or three layer dependant on filler requirements
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
greenwin
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 01, 2005 9:24 pm    Post Subject:
Thank you Big -All - the first solution looks possible - will give it a try
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Damaged hinge on uPVC french door 2 560 Tue Jan 30, 2007 11:48 am
fixing damaged door 6 680 Tue Jun 07, 2005 2:28 pm
Damaged (melted) plastic conservatory door problem! 4 580 Mon Sep 12, 2005 4:09 pm
Water-damaged RSJ replacement 3 140 Fri Aug 21, 2009 9:59 am
Fitting a cat flap in a moulded upvc door 15 740 Mon Jun 23, 2008 3:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
