Hi everyone, hoping someone can help me with some advice with my Hotpoint WMA50P washing machine
It's about 5 years old but generally in good condition due to below average usage. Yesterday, whilst in the middle of a cycle, the electric trip switch in my house flipped, cutting all power. After investigation, the kitchen trip switch had flipped, along with the main power trip switch. Nobody was using anything in the kitchen, so I tried flipping them both back on and all ok.
Only later did I realise that my washing machine was no longer working properly (and I'm guessing it caused the trip to happen). When I try starting any program, the door lock doesn't "click" to lock and the door lock LED flashes forever. I've tried wiggling the door, pushing it in and out (in case of a mechanical issue with the door lock/hinge), but no luck. The door is shutting and the release lever working to open the door, but the door lock LED keeps flashing and the trademark "click" when a program starts (presumably locking the door) no longer happens.
I've taken a look under the hood and removed the door interlock (Metalflex ZV-446). I think this is some sort of metallic switch to lock the door. It has 1 red wire (labelled 1) and 2 white wires (labelled 2 and 3) going to it. I've placed my meter across the 3 terminals and the only resistance registering is between 1 and 2 (red and first white) with a value of about 20 (set to 200K on meter). I can source a replacement of this for about £8 here in the UK. I haven't a clue how to test if this is working properly or needs replacing.
Investigating further, I've traced the 3 wires back to the PCB (not sure of proper name - control panel?) and I think I've spotted a problem. Near where the first white wire (which goes to terminal 2 on the interlock) enters the PCB I can see a clear brown/black "blow out" or damage. Here is a photo of what I see :
This is worrying as maybe even if I replace the interlock (which might not even be faulty), this PCB problem might be a show stopper. Not sure what part number this whole PCB thing is, but if its the "console panel", that appears to be about £50 to replace. If this needs doing, the cost is starting to get a bit high for a 5 year old machine, considering new machines are £200ish in the UK.
Any advice on the above issues or previous experience on how to fix the symptoms are much appreciated. Is it worth buying the interlock as its cheap and see if it fixes the issue? If it doesn't, can the PCB be fixed by some tricky soldering or is it a new PCB?
Thanks in advance peeps
