How much Concrete Ballast do require please - order please
30 May 2008
Nottinghamshire
Hello,
could someone help me out here please.
I'm making a concrete base for a kennel and it is 30 metres from my property bored so I'm going to mix it all with a cement mixer using the raw materials.
it measures.
8 inches deep
6.5 metres long
2.5 metres wide
I worked that out to be 3.2 metres cubed.
My local building supplies advised i'd need 7 tonnes of ballast, and 56 bags of cement!!!!!!! Costing about £900!
Can someone please help me on this, it needs to be a strong mix as dogs will be on it.
Many thanks,
Jon
June 21st.
You'll need the longest day to mix 3.2M³ and you may not finish it before dark!
I reckon 1.5 to 2M³ is the most can be done by two fit guys in one day.
That's with materials close to hand, and minimal distance to barrow.
Price up a pump with the readymix. It'll be done in a couple of hours.
Hi mate,
Thanks for the quick reply.
The problem I have is the distance from the front of the property to the area.
I've had quotes of £440 for a mix and barrow service
£300 for a mixer to dump 3.5 metres cubed on the drive (which could be interesting if it sets)
them almost £1000 in raw materials!
I'm so stuck :(
8" deep seems rather over the top. Much easier to prepare the base with compacted hardcore then go for something like 4" concrete on top of this.
I don't want it to move :mrgreen: !
I've got some rather large dogs and the kennel needs bolting down to this.
renting a concrete pumper seems a huge expense.
having the concrete mixed on site seems a huge amount of work
having gthe concrete dropped off on the drive seems a huge mistake waiting to happen.
HELP!
The pump may cost about £200. It includes two guys who do most of the work. All you have to do is, more or less, tamp/level and trowel it.
The price will be something like:
First hour £125, subsequent hours £75. Additional tubing may be required, therefore chargable.
Add the cost of the pump to the readymix and, considering the ease and speed, it's very cost-effective.
e.g.
http://www.hcppumping.co.uk/concrete-pumping.php
Thank you, I never knew concrete was that expensive though! considering its for dogs to wee on.
200mm is overkill!
150mm compacted mot type 1 and 100mm c35 concrete is plenty.
You can get the gear less than £900 a well.
200mm is overkill!
alastair is spot on with his advice. 100mm is more than enough for a dog run,
and it doesn't need to be any stronger than 6/1.
Get a readymix load and have it pumped in.
Job done.
Don't fart about with barrows and certainly don't have it dumped in a heap - you will regret it.
