DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Earth bonding to gas and water
Author Message
Carloss
from United Kingdom
PostPosted: Thu May 12, 2011 9:53 am Reply with quote
Hello,
Would be grateful for people opinions on this situation I am in....
The Client has requested a 17th edition consumer unit upgrade due to a child receiving an electric In the house. I visited the house to get an idea of what's going on etc.. the gas and water main have a 6mm earth tagged onto them. However, the client has limited funds and can only afford a fuseboard change including testing. Will take an extra day to upgrade the bonding to 10mm as laminate flooring/concrete floors are everywhere! With the supply characteristics that's present, would I be able to leave it at 6mm. Tncs system, main fuse 60a 1361. Or could I put it as a limitation on the certificate? Upgrade of equipotential bonding to water main and gas main in 10mm could not be carried out at present???
Carl
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Thu May 12, 2011 10:02 am Reply with quote
Back to top
 Alert Moderators
Carloss
from United Kingdom
PostPosted: Thu May 12, 2011 10:06 am Reply with quote
Thanks, sorry for sloppy posting, using my phone to write this!
Would it be acceptable if I carried out a continuity check on the bonding if I get readings below 0.05ohms would be acceptable? taking into consideration the type of earthing system and fuse size?
Thanks,
Carl
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Thu May 12, 2011 10:11 am Reply with quote
Back to top
 Alert Moderators
matt1e
from United Kingdom
Thanked: 206 times
PostPosted: Thu May 12, 2011 5:26 pm Reply with quote
holmslaw wrote:
Yes you should test is as part of the cu change, but it will still be unacceptable because the conductors are too small.
They may be ok if the system is TT
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 146 times
PostPosted: Thu May 12, 2011 5:55 pm Reply with quote
The installation is TNCS.
I beleive you can verify 6mm by using adabatic equation.
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
Back to top
 Alert Moderators
matt1e
from United Kingdom
Thanked: 206 times
PostPosted: Thu May 12, 2011 5:58 pm Reply with quote
holmslaw wrote:
Carloss wrote:
Tncs system,
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Thu May 12, 2011 6:01 pm Reply with quote
Back to top
 Alert Moderators
ebee
from United Kingdom
Thanked: 28 times
PostPosted: Fri May 13, 2011 8:39 am Reply with quote
TNC-S (PME) requires 10mm min (even then your supplier might require more)
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Earth Bonding - Separate cables for Water and Gas Pipes ? 9 4580 Mon Apr 24, 2006 9:00 am
Earth Bonding Gas and Water 3 260 Sat Feb 28, 2009 10:21 am
Help - - -Earth Bonding on water main (part plastic ) 4 540 Tue Jul 15, 2008 9:15 am
main earth bonding to water and gas 5 140 Sat Sep 10, 2011 3:36 pm
Earth bonding/water supply query 2 160 Wed Oct 27, 2010 3:35 pm
DIYnot
