DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
RCBO intermitent trip overnight
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
  View previous topic :: View next topic
Author Message
mellis
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 23, 2005 5:15 pm    Post Subject:
Reply with quote Thanks
Hi - have had a Mira shower running back to an MCB for 2 yrs and working fine. Recently replaced the MCB with RCBO (30mA) for extra safety/security. Runs shower fine for ages; no faults/stipping. However, at other times during day/night when shower has not been in use, the RCBO trips (for no aparent reason). Any thoughts?
Also, I understand an RCD is not requied legally, tho obviously desirable for safety. Is this still true? Many thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Jun 23, 2005 5:36 pm    Post Subject:
yes its true though i wouldn't personally wan't to fit a shower without one.
possiblly an intermittent N-E fault somewhere in the shower cuircuit. i'd say start by checking all cables and connections that you can get at.
another posisbility is that someone has borrwed a neutral from the shower cuircuit.(many rcbos don't isolate the neutral so you won't notice until you go to try and use the shower that something has tripped it).
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 19 times
PostPosted: Thu Jun 23, 2005 5:58 pm    Post Subject:
DC Sence RCBO's can trip when you have an earth fault on the installation.
A lost neutral supply to the RCBO will also trip most makes.
Plus what was said above.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Thu Jun 23, 2005 6:22 pm    Post Subject:
going back to what plug said about a borrowed neutral, you could disconnect the neutral to the ahower circuit at the cu (put it in a terminal block out the way, and leave the rcbo switched off, turn off main isolator while working in cu btw) turn on isolator, make sure all breakers except the shower rcbo are on, and go round your house and see what else apart from the shower doesn't work
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
intermitent supply 6 380 Wed Nov 07, 2007 2:08 pm
RCD tripping overnight 47 3460 Sun Apr 08, 2007 9:46 am
intermitent tripper 7 580 Wed Sep 22, 2004 6:12 pm
Overnight Heaters 12 560 Fri Apr 15, 2005 5:06 pm
Would length of circuit make RCBO trip 15 420 Thu Aug 27, 2009 9:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
