Path and steps . . . *updated with pictures*
12 Jul 2008
Wiltshire
Im going to lay a new path and build some steps upto the front door.
Trouble is im not really sure how to tackle it but do fancy having a go.
I'm putting the path mabe a meter wide on the edge of the grass then curving round to the front door with a series of curved steps.
How hard is brick laying also on a curve and how would i cut the slabs to the curve and make a nice finish as the curve will be the face side on show.
I hope i make sence and any help will be really appriciated.
Many thanks![/b]
it would be reasonably easy to do depending on your skill level. Have you laid bricks/slabs before? If you have a level of abilty then it's probably just about looking at other examples of what you're after, to get ideas. If you know the basics, like preparation etc..... give it a go.... good luck,
It all depends on what materials you want to use.
For a small curve radius less than 1.5m you need to use smaller format items like block paving setts. Bricks or step riser units can easily be layed to a curve but if using bricks they need to be layed as closers or soldiers
The easiest way is using step risers and block paving as exampled in this picture
http://www.blockright.co.uk/images/steps.png
If the curve is a big enough radius you can tightly butt them together with no mortar which will avoid the problems you will have if you are not experience laying bricks as on something you will see everytime you enter the house the joints would need to be very uniform and neat which would be hard to do first try.
Updated with pictures...
I was thinking would it be easier to have rectangular steps?
From the picture, i want a path from the pavement upto to the gate, this means loosing the current first step, how would i space the steps out upto the door?
where the gareden is slooping down to the drive and i want the slabs flat/level im going to dig into the lawn, im thinking of putting a wall along the edge then curving round to the left side of door getting higher as i go along.
Any advise/plans/ideas/help/materials to use is really appriciated!
Many thanks!
