Hi all
Just found this site and was wondering if anyone could help me please....
I have a potterton puma 80 wall mounted combi heater, and ive had constant problems with it since ive had it.
This time it took ages (over 30 mins) to ignite, and the pilot light looks pretty small compared to normal. The low system pressure light is on, however there is nearly 3 bar of pressure according to the gauge.
When i turn on the tap for hot water it doesnt sound like its kicking in and heating the water and in the little window all i can see is the dimly lit pilot light, and where you can normally see the flames when the boiler is being used there are none there now.
Also when i try to turn on the central heating i get absolutely no noise from the boiler whatsoever and consequently no heat either :S
Any help would be appreciated, ive tried to explain the problems as best i can but im no plumber. But if any more info is required i will do my best to get it..
Thanks...
Thanks...
