Flow & return valve positions
29 Sep 2011
Hertfordshire
Since embarking on my journey to replace a radiator I have been taking a more in-depth look at my system and notice that some radiators have the lockshield on the flow whilst others have them on the return. Surely this can't be right and must affect the ability to correctly balance the system especially as most have TRVs.
Should I swap over the incorrectly fitted rads?
Th TRVs are quite new Drayton TR4s. I also notice that the bleed valves are oddly mixed - some on the side of the TRV others on the side of the lockshield
Well either you had different fitters (right or lefthanded) or like me he was trying to place them on the least intrusive side of the Rad.
Ok thanks. And the same goes for the bleed valve - doesn't matter which side that's on (as long as it's on the top!). :D
Surely if the lockshield is on the flow it messes up balancing? I was told to balance you open up bothe valves then adjust the lockshield on the return so it is approx 12c lower than the flow.
If the lockshield is on the flow you'd have to have that wide open and use the TRV to shut off - which you couldn't do
Think you need to be told things by someone who knows what they are talking about Ron :LOL:
Some radiators have baffles in them that DOES affect the direction of flow. However, most rads are universal.
Surely if the lockshield is on the flow it messes up balancing? I was told to balance you open up both valves then adjust the lockshield on the return so it is approx 12c lower than the flow.
All a lockshield valve does is control the flow rate though the rad. The slower the flow rate, the greater the temperature drop across the rad. It does not matter which end the LS valve is placed, the effect is the same.
Read How to balance a CH system
Maybe, but that is how it is described in many books and on-line tutorials.
And most of those are based on incorrect, out of date and often both, information.
I have several books written for the industry that I gave up reading due to the woeful inaccuracies and terrible writing/spelling errors.
