DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to remove sides and top of radiator
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
roadster
from United Kingdom
PostPosted: Wed Sep 28, 2005 3:08 pm Reply with quote
This may be a daft question to ask icon_redface.gif . I am preparing to paint a wall with a radiator on it. The radiator is the panel type with fins at the back and the top and sides have a cover that finishes the whole thing off.
How do you remove the top and sides? The sides have a round plastic insert round where the valves are, top and bottom, that rotate with difficulty and appear to hold the sides on but I can't get them to do anything. Do they just pull off or something?
H
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Wed Sep 28, 2005 4:17 pm Reply with quote
if its an lst rad the screw is at the bottom near the valves usually undoes with a bleed key
rhen the cover lifts up and hinges forward
they lift off the same as a normal rad
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Wed Sep 28, 2005 6:50 pm Reply with quote
In most cases the side panels will come off if you slide them up first (about 30mm?) and then pull out. You may have to use a bit of force, and if it all goes pear shaped don't blame me! Once the side panels are off, the top panel just lifts/falls off.
Back to top
 Alert Moderators
roadster
from United Kingdom
PostPosted: Thu Sep 29, 2005 8:04 am Reply with quote
I don't know the manufacturer of the rads but after a bit of fiddling I found the optimum technique....................
Using a pair of mole grips or similar gently squeeze together the rim of the plastic bush until part of it goes inside the end panel. With a bit of a push the whole thing can then be persuaded to go inside and the end panel lifts off.
Herself then cleaned the end and top panels with kitchen cleaner spray (the sort with bleach) and they came back to sparkling white icon_biggrin.gif
I haven't figured how to get the plastic bushes back in yet, brute force and ignorance may prevail..........
Back to top
 Alert Moderators
LinMount
from United Kingdom
PostPosted: Wed Nov 09, 2011 8:52 pm Reply with quote
Did you ever get the top and sides of your radiator back on successfully? I'm just about to try - any suggestions?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How to remove sides and top of radiator 11 17280 Thu Feb 18, 2010 2:02 pm
Radiator Flow and Return Sides 3 1000 Mon Oct 20, 2008 9:49 pm
Radiators hot only at top and sides 3 700 Thu Dec 07, 2006 4:14 pm
Rad input & bleed question - opposite sides ? 3 260 Sun Oct 25, 2009 9:06 am
WHICH NUTS TO TIGHTEN TO REMOVE RADIATOR ? 10 660 Fri Nov 03, 2006 9:17 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
