DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Kitchen lights
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
  View previous topic :: View next topic
Author Message
bbarnes1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 05, 2005 9:05 pm    Post Subject:
Kitchen lights
Reply with quote Thanks
I want to put some under cupboard low voltage light, the connecting cables only come in 1m lengths as far as I can see, is there another way of putting the lights in further apart? icon_question.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sparxfly
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 05, 2005 9:18 pm    Post Subject:
if its the ones i,m thinking about,then unless you hardwire them from a supply and then run them to 12v transformers you might be a bit stuck.i might be wrong but i had to take some back before for a customer because there was only about 500mm of cable for each point pre-wired.think it was a cheap lighting pack from taiwan.
Back to top
 Alert Moderators
Ragnarok
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 11:42 pm    Post Subject:
I had the same problem and the only way of getting round it i had was to break the cabling through a couple of 15amp junction box`s with standard 1.5mm twin and earth making up the difference between the lights.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Oct 07, 2005 9:52 am    Post Subject:
I wouldnt think halogens would be that great under cupboards - you would get a concentrated beam of light on the worktop and big dark spots in between, surely?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Under cupboard lights in a kitchen 9 800 Fri Jan 27, 2006 7:42 am
Kitchen Lights 5 161 Sun Feb 18, 2007 9:10 pm
kitchen cabinet lights 4 560 Sun Oct 31, 2004 7:00 pm
lights under kitchen units 6 2640 Mon Nov 29, 2004 8:36 pm
Under cabinet lights in kitchen. 12 1080 Mon Sep 11, 2006 11:48 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
