Joined: 31 Oct 2005 Posts: 10 Location: United Kingdom Thanked: 0 times
Posted: Mon Oct 31, 2005 7:46 am Post Subject:
Fitting a 10.8KW shower
Hi guys, I am about to fit a 10.8KW Mira shower and have a couple of questions. I have to run the cable from the consumer unit (about 15m in length). The cable will run under floor and for a small distance (4m)in the wall. Is 10mm2 cable OK for this.
Also I may want another shower fitted in an en'suite of similar power is this a problem? I am planning to run two cables to the consumer unit, the second just in case I fit the second shower.
Joined: 27 Aug 2003 Posts: 21979 Location: London, United Kingdom Thanked: 78 times
Posted: Mon Oct 31, 2005 9:08 am Post Subject:
Re: Fitting a 10.8KW shower
Yes. What rating MCB will you be using?
Fitting a 2nd shower is not a problem.
Using both of them might be, as together they will draw 90A...
Also, I'm not sure what LABC will say about it when you tell them...
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Posted: Mon Oct 31, 2005 9:43 am Post Subject:
Cheers for the reponse. I was going to get an electrician in to do the consumer unit end. I guess a 30ma RCB should be fitted.
What is the current limit allowed into a property. We currently have a gravity feed shower in the en'suite and so could stick with that. Do I need to contact my LACB for the one shower?
Posted: Mon Oct 31, 2005 10:12 am Post Subject:
You may struggle to find anyone prepared to do that, given the requirements of Part P, and the need for him to accept responsibility for the circuit if he connects it up.
You are most likely to have an 80A or 100A main fuse, but it could be less.
Oh yes - it is very definitely notifiable work, so if you DIY, you are required to notify them. Both the installation of the shower and the cable itself are notifiable items.
Posted: Mon Oct 31, 2005 10:36 am Post Subject:
I have heard of it but I feel some investigation is in order. I have an electrician relative who'll do the last bit for me. All I want to do really is run the wire so he doesn;t have to be around as I do up my bathroom. So really I am running one cable.
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Mon Oct 31, 2005 11:13 am Post Subject:
Would not advise the second shower, while I do not take the section of the regs on diversity as gospel, if you have two showers of that rating on a 100A SP supply, it is reasonable forseeable that in circumstances which are not too exceptional (two people showering while someone boils the kettle) that the service fuse would be overloaded, and while they are quite resiliant things, its not good practice IMHO to design something which is going to be frequently overloaded.
Posted: Mon Oct 31, 2005 11:34 am Post Subject:
No, sorry you misunderstand. The electric shower I am fitting will be mains fed. The second shower in en'suite which is currently an un pumped gravity fed shower off the hot water tank will remain gravity fed.
Posted: Mon Oct 31, 2005 11:36 am Post Subject:
What we are doing here is the main bathroom is going to have a pumped shower fed from the central heating system, with electrics only to pump the water, and a 8.5kw electric shower in the small toilet for occasional use, if someone wants to shower while someone is taking a bath, or if the hot water has all been used up, etc
Will mean we finally get rid of the electric shower in the main bathroom that seems determined to set itself on fire... (connections are starting to break down inside and get hot)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
