Hi Guys, I'm new here and have a recurring problem which I hope you can help with?
I have a Sime super 4 boiler and have been getting a problem where it all works fine for anywhere between 1 and 3 hours. Then what happens is the fan continues to run but the boiler will not ignite. when switched off and then back on again it usually works for one time then fails again, although the fan never stops running and continues to pump ever cooling water around the radiators?
I have fitted a new fan and yesterday a new air press switch, all to no success................................. Water pressure cold is about 0.6 bar and when hot just about 2.0 bar.
HELP plesae where do I look next and/or who do I contact.
