zanussi wjs1265 wont start
19 Nov 2005
London
above zanussi will not start, electricals all ok, start button lights, after choosing wash cycle and press start just hear a clicking noise
i've only had to repair one of these with the same symptoms.
on that occasion it turned out that the door lock had shorted out.
i replaced the lock to discover that it still did not work. i then removed the lid and accessed the circuit board to discover that the door lock had blown a track on the p.c.b. a simle soldering in of a replacement link ( piece of wire) sorted the problem.
can't guarantee that yours will e the same but it worked for me.
one caution would be that if you repair the board and try with the same lock, if it is faulty the board may be more seriously damaged as you will have repaired the weakest point and risk causing worse damage elsewhere.
Thanks Keith, sounds like I need to get somebody to look at this.....
