ElectricNick
Joined: 19 Dec 2005 Posts: 2 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Mon Dec 19, 2005 1:20 pm Post Subject: Dimmer Hell |
Can anyone Help with this,
I moved into a house where the kitchen/dining room have spot lights controlled with a dimmer switch - different dimmer switches for kitchen and dining room.
the kitchen lights have never dimmed and the dining room lights dimmed until recently. Each halogen (12v 50W) is connected to its own transformer. last week i turned the dining room lights on and all 4 transformers appear to have blown! (at least £15 each!)
I went out and bought some more, installed them and now the lights attached no longer Dim.
Are there specific transformers i should get?
For all 4 transformers to go at once does it sound like a dimmer switch problem?
I had assumed that all electrics in the kitchen/diner would be fine since they were installed on Carol Vordermans Better homes for the previous owners.
any help greatyl appreciated.
thanks |
teachergeezer
Joined: 22 Nov 2005 Posts: 29 Location: Buckinghamshire, United Kingdom Thanked: 0 times
Posted: Mon Dec 19, 2005 1:49 pm Post Subject: |
You need to check that the transformers are dimmable - not all are.
Secondly you need to ensure that your dimmers are suitable for inductive loads, otherwise they will not last very long. It may be that you have a dimmer switch problem, rather than all 4 transformers going simultaneously, however if they're not dimmable you'll have to replace them anyway.
Check for voltage up at the transformers, that'll tell you which end the problem is.
Good luck. __________________ If you think education is expensive, try ignorance!!!
Andy McIntyre |
ElectricNick
Posted: Mon Dec 19, 2005 2:09 pm Post Subject: |
Thanks for the help Teachergeezer,
I think that the previous transformers were dimmable - and so will try and get the same ones!
however all four previous transformers definitely went at once so i may have a problem at both ends.
cheers |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Mon Dec 19, 2005 4:15 pm Post Subject: |
How did you decide that the transformers had failed, and not the switch?
Not dimming is a sign of dimmer failure.
Have you got:
1) Dimmable transformers?
2) Dimmers that can handle transformers?
3) The right leading-edge/trailing-edge match?
As for CV - an intelligent and attractive lady, but probably knows b*gg*r-all about electrics... __________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth. |
Steve
Joined: 15 Apr 2005 Posts: 12848 Location: Yorkshire, United Kingdom Thanked: 21 times
kendor
Joined: 16 Mar 2004 Posts: 5066 Location: United Kingdom Thanked: 0 times
