Joined: 04 Jan 2006 Posts: 4 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Jan 04, 2006 8:39 am Post Subject:
Breaking Glass
Help
I had new windows fitted some10 years ago and all was fine until 3 years ago when various fanlight windows have shattered. It is always the outside glass.The units have a tulip design leaded pattern and I wondered could the lead be stopping natural expansion and contraction due to heat / cold. They were fine for 7 years and now we have replaced at least 8 units and a further 3 broke over Xmas. Is this common? There does not appear to be any movement in the house.
Posted: Thu Jan 05, 2006 3:35 pm Post Subject:
Broken Glass more info
Many thanks for your comments Masona
Upvc, Double glazed 25mm gap. The windows were fitted to existing openings. Steel catnic lintels fitted throughout (existing) no load bearing on the frame. The frame appears to be correct sized and equally spaced.
The lead is stick on. It is fitted to both sides of the external glass.
Joined: 05 Jan 2003 Posts: 10853 Location: Essex, United Kingdom Thanked: 7 times
Posted: Thu Jan 05, 2006 6:00 pm Post Subject:
Right, have a look at the clip-on beading, they have been known to expand and dig in to crack the glass, so give it a little trim back on the mitre edge. The other theory is you may have the wrong size rubber seal beading causing the glass to pressure to the outside. Is the cracks always in the same place, if so, where about is it?
__________________ Always judge a man by the way he treats someone who is of no use to him
Posted: Fri Jan 06, 2006 2:04 pm Post Subject:
The windows have various types of breaks. Some have a single horizontal crack approx half way up the window and others that shatter as though they have been hit in the centre of the glass with a hammer. When the replacement unit is fitted the same style of break does not necessarily happen. The last window to break was a shatter type and it even stretched the lead inward with the break almost as if it were an implosion
Joined: 10 Feb 2004 Posts: 598 Location: Essex, United Kingdom Thanked: 0 times
Posted: Fri Jan 06, 2006 7:26 pm Post Subject:
Are the windows on the same side of the house?
You could look around the area in front of the windows for lead pellets or ball barings. It's not unheard of, for littles tykes (B******s) to use air guns on peoples windows when bored. Also have a word with Neighbours, ask if they know anyone else who's had problems.
Posted: Mon Jan 09, 2006 2:02 pm Post Subject:
Hi again
The windows are on 3 sides of the house and the rear is un overlooked with locked gate so I dont think the problem is with human aided breakages...But thanks
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
