DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extending Ring Main Advice
This topic originated from the How to page called Extending a ring circuit using existing sockets
Click here to return to the page called Extending a ring circuit using existing sockets.
  View previous topic :: View next topic
Author Message
Largemoo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 16, 2006 8:22 pm    Post Subject:
Reply with quote Thanks
Hi, I need to extend a ring main to put a couple of new sockets in. The problem I have is that the only place for the new cables to be situated is behind the skirting board - However I already have central heating pipes behind the skirting board (concrete floor).
Can the 2.5mm cables be situated next to a central heating pipe that obviously gets very hot? how close can they get? Is there such thing as heat resistant cable?
Any advice welcome.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Jan 16, 2006 8:34 pm    Post Subject:
Re: Extending Ring Main Advice
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
ebee
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 16, 2006 10:07 pm    Post Subject:
Ban
You can't put the cables behind the skirting board anyway
If a cable is run in joists under a floor and then up to a point then it almost always invariably runs behind a skirting surely.
This is not what you meant is it?
REegards,
EBEE
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Jan 17, 2006 2:37 am    Post Subject:
In the situation you describe the cables run vertically to the sockets - this is OK.
Largemoo wants to run them horizontally behind the skirting - this is not OK.
__________________
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Jan 17, 2006 2:50 am    Post Subject:
bare copper sheathed MICC would certainly be up to the heat and has an earthed metal layer so avoiding the cable routes problem. but it needs to be stripped with a special tool and glanded off with a special pot. Some sparkies tell me its hard, others reckon its easier than SWA. I have no personal experiance to comment.
Can't you just chase horizontally from one socket and vertically from the next meeting up to form a dog leg. that way you stay within permitted routes and away from the hot pipes so no special cable needed.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Extending a Ring Main 3 3800 Wed Oct 20, 2004 10:23 pm
Extending kitchen ring main + new oven. 5 380 Wed Aug 06, 2008 9:24 pm
Extending Ring Main 4 440 Sat Jun 02, 2007 8:09 am
Extending ring main using spur 2 540 Fri Feb 09, 2007 10:08 pm
Extending a ring main using existing sockets 8 760 Thu Mar 09, 2006 12:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
