Hotpoint WM54 Overfilling.
16 Jan 2006
Kent
Hiya,
My Hotpoint WM54 has begun over filling. At the start of the cycle, it fills up and just continues untill the water starts to leak from the door. The drum doesn't turn although it is free moving when pushed. An engineer came out to fix it today. When he was here, it worked fine after he'd fiddled with it but now, 4 hours later, the problem has returned. Any ideas? Thank you for any suggestions.
yes.. call him back again.. everyone does it to me. so get on that phone and shout.. sounds like the pressure hose is blocked. hotpoint had some faults with the sump/pressure hose.. they now do it in a kit form if you need to replace it..
Thank you so much for the advice. I will give it a try. I really appreciate it.
Best Regards.
