DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fitting snowboard to slate roof
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
blondini
from United Kingdom
PostPosted: Sun Mar 26, 2006 6:47 pm Reply with quote
The supplier of a glass roofed conservatory has suggested that a snowboard should be fitted to the house roof in order to protect the conservatory roof from falling snow.
I intend to do this myself before the conservatory is built but there's very little info coming up on a search. Has anyone done this, or know how it is best done?
Back to top
 Alert Moderators
Roofer
from United Kingdom
Thanked: 14 times
PostPosted: Sun Mar 26, 2006 7:53 pm Reply with quote
Snow guards are easy to fit -just screwed to fascia.
Easily available from Roofing Merchants.
Asphaltic are nationwide
http://www.asphaltic.co.uk/index.html
Back to top
 Alert Moderators
blondini
from United Kingdom
PostPosted: Fri Mar 31, 2006 7:12 am Reply with quote
Thanks Roofer, I didn't realise they were called snow guards, I'd been searching for 'snow board'.
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Sun Aug 26, 2007 10:59 pm Reply with quote
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 852 times
PostPosted: Mon Aug 27, 2007 7:08 am Reply with quote
i would advise fitting through the fascia and into the rafter ends, as you don't want snow, snow guard and fascia board falling onto the connie roof. icon_wink.gif
Back to top
 Alert Moderators
mrsb17
from United Kingdom
PostPosted: Mon Nov 29, 2010 11:11 pm Reply with quote
We have just in time, sucessfully put up our SNOW GUARD. We learned the hard way last year, when two of our conservatory roof panels popped in because of the snow falling off our house roof. Our conservatory runs right across the back of the house so we thought it was going to be an impossible task, but we managed it. We had 3 very large brackets made. Shaped as - up/across/up, at a local fabrication shop from a template we had made out of metal beading used on corners of walls before plastering.we found we could bend it very easily. The brackets were attached to the wall underneath the guttering and facias with 10mm coach bolts. The middle bracket was a little more tricky but can be done by laying scaffy boards on the conservatory roof to stand on. Once all the brackets were fixed, we used 2 16ft decking boards which were screwed into position giving us a 10" wall of wood at the bottom of our house roof to stop the snow avalanching off! I can report it works perfectly.Hope I havent confused too many people........lol
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Fitting flue in slate roof 2 3220 Wed Dec 10, 2003 10:13 pm
fitting roof valley boards where different roof styles meet! 7 3820 Fri Apr 16, 2010 9:51 pm
Fitting a velux in a trussed roof? 3 540 Sun Nov 09, 2008 7:17 pm
Fitting a frameless glass roof 3 980 Mon Dec 17, 2007 1:04 pm
Fitting a Flat Roof Skylight?? 2 340 Sun Apr 17, 2011 6:58 pm
DIYnot
