Noisy Indesit WG1300T
5 Apr 2006
Glasgow
The machine makes aloud thumping noise when spinning. Ther seems to be a lot of movement by th drum. Any ideas?
This will happen if you overload the machine. If it isn't that, rotate the empty drum and check if there is any undue movement or noise, if so, may be the bearing going. Failing that, take the top off and check the the concrete weights and the supporting struts and springs are still firmly attached to the drum and the machine casing.
