I have been having a really bad time changing a florescent light fitting to a four bulb light fitting.
I disconnected the strip light and there were three wires - two for the circuit and one for the switch. I then tried to connect all three wires into the new light fitting, 3 black wires into neutral, 3 red wires into live and three earths into earth - it is a metal light fitting.
Fortunately I could not do this as the holes in the new light fitting where too small so I connected the three wires together in a junction box (black to black etc.) and then connected a fourth wire to them so that I had one single wire to connect to the light fitting.
Yes, I know what you are thinking, the switch has two lives which I realised after I had switched the power back on. Stupid me. The lights came on fine when the power was switched on but when I turned them off by the switch the fuse went in the fuse box.
I then wired them into the junction box in the same way a ceiling rose is wired, and the same way as the diagrams show on this website taking into account that the switch has two lives.
However, now the same thing happens still. When I flicked the switch to turn them on after the power was switched back on the circuit blew again.
The only difference my system has to most of the diagrams is that I have wired all of the earths together so that the three inlet earths are connected to the one outlet earth in my junction box.
Does anyone know why the fuse keeps blowing when the switch is pressed? a quick response would be very much appreciated.
