I have use a 32mm plastic weld pipe on a new sink and it has developed a leak at a joint where it goes around the bath frame and joins to a 40mm pipe, what is the best way to fix it?
Should i cut it out or can I try puting more glue around the joint it to save buying 2 x 45s and 32-40 reducer.
thank you
thank you
