Godders46
Joined: 04 May 2006 Posts: 1 Location: Liverpool, United Kingdom Thanked: 0 times
Posted: Thu May 04, 2006 4:38 pm Post Subject: Under stair angled door? |
Hello there,
I am in the middle of renovating my stairs - freeing up some unusable space from the connecting larder, fixing broken risers and installing a banister. I want the end result to be pretty traditional looking. I want to wall off the area under the stairs but I want one door into it - approx 2 foot wide.
Does anyone know where I can get an angled (and preferably panelled) door that will meet my requirements?
Many thanks in advance, Gary. |
Scrit
Joined: 21 Dec 2005 Posts: 1094 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Thu May 04, 2006 8:45 pm Post Subject: |
Make it yourself or ask a joiner like me  Every one is different (size, going, etc) so there's no such thing as a set pattern.
Scrit __________________ Measure twice, cut once - except fingers! |
splinter
Joined: 10 Apr 2004 Posts: 778 Location: Antarctica Thanked: 0 times
Posted: Thu May 04, 2006 10:04 pm Post Subject: |
A simple but effective wat of making a panel look door is out of MDF .Cut the shape of the door out of a sheet of MDF ,then what will be the rails and stiles out MDF glue these onto board already cut YOU can form a moulding on these with a router before you fix them, if you have not got a router you can always buy the moulding of you're choice
YOU could use this method to panel out under the stair case also  |
