NICKY123
Joined: 12 May 2006 Posts: 2 Location: Roxburghshire, United Kingdom Thanked: 0 times
Posted: Fri May 12, 2006 6:39 pm Post Subject: Cable Routing |
I am extending a kitchen and need to route cable. I understand that i can run cables buried in the wall vertically to the sockets, but not horizontally between them. can i run surface truncing attached to the wall under the work surface to join them? or do i have to go near the ceiling or floor and put them in the wall there? |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Fri May 12, 2006 6:41 pm Post Subject: |
They can go horizontally. safe zone is horizontal and vertical from fittings, as well as 15cm from any corner, floor and ceiling. |
NICKY123
Posted: Fri May 12, 2006 6:53 pm Post Subject: |
Would surface truncing under worktop do (and meet regs). creating channels into brick is hard work! |
superspark
Joined: 19 Feb 2006 Posts: 54 Location: Middlesex, United Kingdom Thanked: 0 times
Posted: Fri May 12, 2006 6:54 pm Post Subject: |
150mm only from ceiling and corners, not floors. |
Steve
Posted: Fri May 12, 2006 6:57 pm Post Subject: |
nicky, i told you, the cables can go horizontally between sockets. And it doesn't matter how deep or shallow or protected they are. Frankly, if you drill a hole between 2 sockets in plaster, you deserve all you get. |
Fratton sPark
Joined: 27 Apr 2006 Posts: 62 Location: Hampshire, United Kingdom Thanked: 0 times
Posted: Sat May 13, 2006 12:25 am Post Subject: |
Nicky, Superspark was right mate, the safe zone don't include 150mm from floor. But u can run them horizontal ( as stated) between fittings. If that happens to be under the worktop surface, that's fine. As long as the cables run horizontal, or vertical between accesories, that's grand, basically. But having said that, also depends on your exact situation,mate. Sorry, I know that probably don't help much, but I'm pi**ed, lol |
Pens
Joined: 17 Jan 2006 Posts: 2433 Location: Kent, United Kingdom Thanked: 0 times
