DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIY replacement of Creda C361E Fan Oven Element
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
braychurchmouse
from United Kingdom
Thanked: 2 times
PostPosted: Mon May 15, 2006 1:08 pm Reply with quote
Pretty sure the element has gone. Oven failed, but fan still runs and thermostat light comes on. Checked timer set to manual etc etc. I see I can get new element for £16 on ebay or about £25 from web suppliers. (any advice welcome - the £16 eBay guy says Genuine Creda Part! ).
So my question is...is it a reasonable job for a competent DIYer? or should I call in the repair man for a £50 call out fee for starters (living in SouthEast so have to pay through the nose for this sort of repair icon_sad.gif ).
Only other thing that concerns me a bit is that when the oven went off, the RCD tripped (MCB not tripped though) . Would that be expected or does it indicate some rather more sinister problem?
(for the record.... if anybody is thinking of buying a new oven - After 25 years of faultless service from a Belling oven we decided to get a more modern one, and this Creda failed after just 3 years... icon_confused.gif ).
Many thanks in advance for any advice offered.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 221 times
PostPosted: Mon May 15, 2006 1:26 pm Reply with quote
Yes its a DIY job.
Ensure OFF AT MAINS
Element maybe removable from inside, it could also be part of the fan assemble
Back to top
 Alert Moderators
braychurchmouse
from United Kingdom
Thanked: 2 times
PostPosted: Tue May 23, 2006 10:40 pm Reply with quote
Thanks diyisfun for your encouragement. I thought folk might like to know how I got on..... icon_surprised.gif .
WARNING l-o-n-g post!!!!
Well the first task was to source a replacement element. First stop try manufacturer's Customer Service number...oh but what's this?... its an 0870 number ....and yes the first 3 minutes of music were very nice but not really worth the 50p per minute it was probably costing me! So I sent them an email...i'm still waiting for a reply. So not only do Creda make me an oven that conks out after 3 years, but they then want me to pay through the nose to get a spare part. No way.
Tried Google...definitely a few possibilities... but Google pointed me to an ebay seller...darn it why didn't i think of that first!!! It seems as though there are quite a few sellers on ebay dealing in new appliance spares. Prices ranged from £34.50 (and I bet that would be the sort of price i'd have to pay Creda direct) down to less than £10. But the cheapest ones were clearly oem and not actual Creda parts, so i was a little wary. I finished up buying a pukka Creda spare from "best-deals-ron" on eBay. £13.97 inc VAT plus £2.39 postage. I ordered it 3pm and it arrived two day later (he tries to catch the post if you order before 4pm.). Looks like a proper Creda label (or a good Chinese repro!) with Creda Part number 6204370.
Oh yes and it has in big red letters "In the interest of consumer safety this part should only be fitted by a suitably qualified person with the machine disconnected from the mains supply." So be warned!!!
I found it quite straight forward taking of the backplate of the oven from the inside. (when I first considered this job I had visions of dismantling the whole oven from the back, removing insulation etc etc.) The whole job turned out to be a half hour job effectively, although it took me quite a bit longer because I cleaned stuff up while I was doing the replacement.
If I had to do this again, and not doing any cleaning up, I think it would be a 20 minute job at most. So in this part of the world (South-East commuter-land!) that would be about £35 call-out and £15 time PLUS VAT. Whoopee saved myself nearly £60... and maybe saved another £20 on the price of the part.
In fact I was so pleased with myself that I took a few photos and did a bit of a write-up (see below).
You experts probably think its no big deal, but I was really pleased with myself and hope it helps someone in a similar situation.
Needless to say do not attempt any electrical repairs unless you are reasonably competent AND SWITCH OFF/DISCONNECT before you do anything. These tips only apply of course to the Creda Concept Fan Oven, though i guess others may be similar. I cannot be responsible in any way for mis-use of these tips!!!
I've put the photos up on flickr.com as a set at
[url] http://www.flickr.com/photos/robwilla/sets/72057594143321693/ You can click on the "Slide show" button to view each of the eight photos in sequence. OR you can click on each photo in turn and there is a piece of explanatory text for each photo. If you sign up for flickr.com (its free icon_smile.gif ) you can leave comments for other viewers or point out any mistakes in my photo or text! I hope the link has a reasonable longevity as Flickr itself is still in Beta release and keeps on changing, but its a great free repository for photos.
Anyway here's the story....
FIRST DISCONNECT SUPPLY!!!!
Remove 4 screws at each corner of the backplate. Pozidrive No2 seems to fit best. The backplate will slip down a bit, but held up by the oven light cover.
Carefully remove oven light cover. About half a turn anticlockwise. this is likely to be covered in gunk...a great opportunity to clean it up maybe icon_smile.gif. (in fact it might be better to unscrew the oven lamp cover first before unscrewing the 4 retaining screws). Anyway whichever way you do it the oven backplate should then be free to remove by pulling forward...you may need to jiggle it around the side panels protrusions.
Remove element by unscrewing the screw between the two points where the element goes in. The screw also has a sprung washer between its head and the element plate ... careful not to loose it! The element just lifts off the retaining brackets at the base. Bring forward carefully as the connection wires will be attached to the element. They should just slide off with a little coaxing...or maybe with the use of some pointed pliers.
Make sure the connecting wires don't disappear back down the holes!
I checked that the old element had really bust...using a meter set to measure resistance, it showed open circuit, so yes it had definitely blown!!
Resistance of the new element measured about 20 ohms.
The new element was then connected up to the spade connectors. I found I could just slide them on, but you might need some pliers if they are too tight. If they are too loose you might be able to compress them or better still replace them...but I think that's out of my area of competence!!
Rest the base of the element on the slots in the retaining clip..making sure the two loops are resting properly in the slots. Then secure the rectangular plate with the screw ... making sure to put the spring washer between the screw head and the plate. This is a bit fiddly. I found I had to pries the loops upwards before the screw found its hole. Note the error in the text on the photo...you can't actually fit the glass cover to the oven lamp until you have fitted the backplate..next step!!!
After fitting the element, but before replacing the backplate I reconnected the electricity supply and briefly checked the element was in fact working. Just a quick try as there isn't at this stage any cover over the oven bulb so you might damage it if heated up too hot!! (AND Remember after disconnecting the electricity you have to reset the oven timer from Auto to Manual...and of course close the oven door to activate the element. I left the door open and wondered why it wasn't coming on!!!).
OK so the element works...hooray! But don't forget to DISCONNECT from the electricity supply before you complete the final steps… putting the backplate back on and replacing the newly cleaned oven light cover.
Before replacing it, I took the opportunity to clean the backplate. There was a lot of encrusted gunk on the back of the plate, partially blocking the fan vents..I wonder if this contributed to the element's demise? I replaced the oven bulb which had failed (15 watt SES 300 degree - I got a Philips T22 E14 about £2 from local electrical supplier - who incidentally told me he stocked the elements too!). Replace the back plate with the 4 screws - you did keep them in a safe place didn't you? I took the opportunity to clean the glass on the oven door too. Wow...now we can actually see the stuff being cooked for the first time in a couple of years!
I then checked out the oven by starting at 100 degrees and checking the thermostat went out after a couple of minutes. then 150 degrees...another couple of minutes..then 200 and 300. Seemed ok.
Hope this helps! If any of you experts out there spots a mistake or omission in my description please feel free to post a correction.
ps.. my wife says the oven isn't really as dirty as it looks in the photos!!! icon_lol.gif
Back to top
The following 2 users say thank you to braychurchmouse for this useful post:
Shelljones (14 Mar), Tank72 (25 Nov 2011)
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 221 times
PostPosted: Wed May 24, 2006 7:14 am Reply with quote
Well done, thanks for the feedback.
The biggest problem in doing this type of replacement yourself is that the wire gets cooked & brittle at the element connection & the terminal breaks off.
Back to top
 Alert Moderators
empip
from United States Minor Outlying Islands
Thanked: 50 times
PostPosted: Wed May 24, 2006 1:15 pm Reply with quote
bray ... Is that a Micronta multitester? (I guess there may be a few different makes all looking like your picture)
I have a Micronta carefully kept, including box and paperwork since 7/5/82... Bought from Tandy £9.95 !! (sad) icon_razz.gif
3 yrs ago when it was 21 years old, I put it through my company's electrical calibration dept. .. They said twas ok and reading within the specs quoted on the 'Instruction sheet' ....
Back to top
 Alert Moderators
braychurchmouse
from United Kingdom
Thanked: 2 times
PostPosted: Wed May 24, 2006 9:18 pm Reply with quote
Blimey empip, you must be as old as me...I thought we'd all died off! It is indeed a Micronta...and would you believe it the receipt is still in the box £11.95 in 1985!!! and yes bought at Tandy. Never let me down, except once...but it worked in my favour. I was buying some second hand speakers and I tested them with the meter...it showed 1 ohm or less...so we agreed they had probably melted the speaker windings and i got them at a reduced price...even though they seemed to work ok. Got the speakers home and cautiously plugged them in...perfect...tried meter again...1 ohm as before...then moved the dial back and forth...bingo 8 ohms...So the moral of this extremely off-topic narative is twiddle the knob to make sure invalid resistance is overcome icon_wink.gif.
Anyway, glad to see folks can see the piccies...quite enjoyed doing it.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1081 times
PostPosted: Wed May 24, 2006 9:29 pm Reply with quote
Where can I get one of those Precision AligNment devices?
Back to top
 Alert Moderators
braychurchmouse
from United Kingdom
Thanked: 2 times
PostPosted: Wed May 24, 2006 9:49 pm Reply with quote
Dunno where you get them...very rare...just found a set of them in the back of the kitchen cupboard. Very conveniently there was a range of sizes so you could choose one the exact size to hold the torch at the right angle to illuminate the back of the oven. They even had a handle attached so you could turn them, and a nice heavy copper base so they were stable. icon_smile.gif
Back to top
 Alert Moderators
alrighttreacle
from United Kingdom
PostPosted: Tue Aug 30, 2011 7:42 am Reply with quote
Hi, Great advice on how to replace an element. I did make a few calls to companies to get a repair as my oven was not heating up. everything else worked and fan was working so i read it must be element. I was quoted £140 and £160 for work to be done. I did a bit of surfing on net and a lot of people said you can fit element yourself.
Well I purchased one for £10 and then came across your item on how to replace it.
Thank you. Really helpful and i did it and I am a woman. lol
I suppose with electric cookers it is relatively simple as most parts are straight forward to fit if you know what you are doing and there is so much help online. Very costly otherwise.
I am chuffed to bits. I think washing machines etc are a different story but hey ho my oven is fixed. I bought this when it was top of the range £750 and the thoughts of having to buy a cheap cooker for £200 or £300 was not appealing as they dont work as well. Thank you all for your great help.
Back to top
 Alert Moderators
braychurchmouse
from United Kingdom
Thanked: 2 times
PostPosted: Tue Aug 30, 2011 9:27 am Reply with quote
Hi ..treacle. Well Done! Glad it was some help after 6 years. I see it's had quite a few views meanwhile icon_smile.gif
Just realised the link in an earlier post to the Flickr photos and notes is now 6 years old...I checked the slide show and it seems the photos were pushed off my free limit of 200 photos. So I've just deleted a few others so it should work ok now. There are notes attached to each photo so after you've watched the slideshow you can look at each photo in the photostream and see the notes attached to each one.
Actually surprised it works at all as I moved most of my photo storage to Photobucket when eBay banned Flickr connection icon_sad.gif
I'd be grateful if anybody could confirm they can see the complete slide show now.
Cheers
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 221 times
PostPosted: Tue Aug 30, 2011 12:10 pm Reply with quote
Its always good for others when people give feedback.
Back to top
 Alert Moderators
Tank72
from United Kingdom
PostPosted: Fri Nov 25, 2011 3:10 pm Reply with quote
Thank you, thank you, thank you!
My element went a couple of nights ago whilst in the middle of cooking my tea!! Rang around several electrical repair places and had various quotes.
Thought I'd see if the part was available locally, as I couldn't be bothered to wait for delivery and it was available for £24 from my local electrical suppliers.
I have just fitted it in about 10 minutes and saved myself around £60!!
Thanks again.
Back to top
 Alert Moderators
Tank72
from United Kingdom
PostPosted: Fri Nov 25, 2011 3:13 pm Reply with quote
Cheers
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Candy TCP21/1 Oven Element replacement 3 320 Tue Sep 21, 2010 9:24 am
Replacement oven element 5 700 Wed Mar 07, 2007 12:12 am
Fagor fan oven element replacement 2 20 Wed Mar 07, 2012 9:12 pm
Belling Double Oven XOU499SS grill element replacement 3 760 Fri May 07, 2010 9:45 pm
Rangemaster Elan 110 lower oven element replacement 2 100 Fri Sep 07, 2012 3:11 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
