DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Plaster Directly On Electric Cabling
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
fitzer
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 6:20 pm    Post Subject:
Reply with quote Thanks
I\\\'ve got a channel that\\\'s about 12mm deep, and a cable to a light switch which is 4mm deep.
If I put oval conduit in, I reckon I\\\'ll have to chisel into the brick work to leave enough depth for a decent layer of plaster.
Is this what needs to be done, or can you get away with plastering directly on to the cable?
Any thoughts / comments appreciated.
Cheers,
Fitz.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Aug 05, 2006 6:27 pm    Post Subject:
you cant directly plaster over a cable
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
fitzer
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 6:40 pm    Post Subject:
Dang,
Thought you might say that.
Thanks for the quick response.
Back to top
 Alert Moderators
Gasman1015
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 6:54 pm    Post Subject:
Yes, you can plaster over the cable, better job in capping though.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Aug 05, 2006 7:07 pm    Post Subject:
you can, but you must not, as it has no mechanical protecton
__________________
Forum = Opinions
Back to top
 Alert Moderators
crystal ball
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 05, 2006 7:11 pm    Post Subject:
If the cable is sheathed it does not need any further protection, no need for capping or conduit
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Sat Aug 05, 2006 8:18 pm    Post Subject:
pvc/pvc cable requires no mechanical protection plastered in a wall provided they run in the safe zones.
Although we all no its good practice to fit capping for impact protection.
Back to top
 Alert Moderators
Jaymack
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 06, 2006 2:59 am    Post Subject:
If the cable is run in the safe zone as mentioned already, there is no need for any protection for this cable. Capping is advised where someone else is doing the plastering later to avoid trowel damage. Chiselling into the brickwork is to be avoided for cable runs, since it weakens the building structure.
Next Please.
Jaymack
Back to top
 Alert Moderators
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 06, 2006 9:28 am    Post Subject:
Flat twin and earth cable already has mechanical protection - that's what the grey sheath is for. It can be buried directly in plaster, but as others have said, capping (plastic or galvanised) is better. And if you have 12mm plaster depth that is plenty deep enough for capping.
Back to top
 Alert Moderators
The Jeep
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 06, 2006 3:16 pm    Post Subject:
According to Building Regs, you can chisel vertically up to 1/3 of the thickness of the wall. Horizontal chases are limited to 1/6th wall thickness.
Back to top
 Alert Moderators
thatguy250
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 18, 2009 7:54 pm    Post Subject:
just put it in a conduit. Get galvanised, the plastic stuff always splits. It just might save having to rip it all out when someone hammers in a tack for a picture frame and gets a nice bang icon_smile.gif
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Oct 18, 2009 7:56 pm    Post Subject:
__________________
I downlights
Back to top
 Alert Moderators
thatguy250
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 18, 2009 8:03 pm    Post Subject:
ye, probably, I was just bored and found myself happily going through writing obvious comments on loads of questions completely oblivious to when they were posted lol icon_redface.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Can I fit an electric shower directly over the bath ? 2 3080 Mon Nov 20, 2006 3:38 pm
plastering cable directly 3 3600 Mon Mar 26, 2007 4:41 pm
wiring a light directly into a 13 amp socket 6 720 Tue Jun 08, 2004 12:00 am
Fitting 13A sockets directly to trunking... is it legal? 3 800 Sun May 13, 2007 9:18 am
Spur off a ring directly from the MCB terminals 5 620 Mon Oct 30, 2006 9:28 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
